It'll be all white on the night
Tokai guitar discussion
Post by iainblack » Fri Jan 25, 2013 5:24 pm
Tokai J5R653 Custom Edition. Think it needs metal vol and Tone knobs. Did someone on here recommend a chap who makes truss rod covers etc.
So 80's, check out the catalog
http://www.tokairegistry.com/images/cat ... ai8703.jpg
Please check out my Tokai Strat Book: http://www.blurb.co.uk/my/book/detail/2060524 Image
Post by iainblack » Sat Jan 26, 2013 11:52 am
Better with black metal knobs
And typical of Tokai electronic on exploring:
bluesyrat
Post by bluesyrat » Sat Jan 26, 2013 5:36 pm
8)
fusion music make me puke
Post by iainblack » Fri Feb 15, 2013 11:05 am
I had a spare back plate that fits exactly. note you do not need to load the strings of the Ayres rocker from the back and neither do you have to cut your balls off (ouch! :D ) , you can top load so this is fine:
Still not a quick change if a string ones live!
Post by iainblack » Fri Feb 15, 2013 11:10 am
I also has a truss rod cover from an Encore neck that was curved. dropped it in boiling water and it flattened out (may work in reverse for others interested). The size fits but the bottom screw holes of the triangle are slightly out so I chose to leave them out. Just finishes it off nicely:
Post by iainblack » Fri Feb 15, 2013 11:12 am
And here is the final look. Think I may do white Airfix paint touch ups for the dings. I will call this my Jackson eater in tribute to Eqypt guitars that did a Kramer eater!
P.s I do have a black plain trem arm too, just forgot to fit it for the photo!
Post by iainblack » Sat Apr 13, 2013 10:39 am
The inspiration, the Dinky. Cousins. Pity it doesn't have the sharifian inlays!
