New amp
Max The Dog
PostPosted: Mon Aug 20, 2012 2:43 am    Post subject: New amp Reply with quote
Just got this, English Valve Amps SHG 5w. The chap I got it from put Marshall badges on it but gave me the EVA one also. The only problem is he forgot the lead to connect the amp to the cab so I have'nt fired it up yet. waiting expectantly for the postman.
PostPosted: Mon Aug 20, 2012 3:04 am    Post subject: Reply with quote
Looks very nice Pete, you've been trying out several small amps lately hope this is the one.
ez
PostPosted: Mon Aug 20, 2012 3:12 am    Post subject: Reply with quote
Ooh nice. Is that an 18 watt TMB or Superlite maybe?
Edit: silly me for not reading. 5 Watt. What kinda specs does it have?
Max The Dog
PostPosted: Mon Aug 20, 2012 5:42 am    Post subject: Reply with quote
Thanks Jacco, I think this is the one as I have run out of money now!!
(unless anyone has a Cornell Romany to trade)
EZ Yes its a 5w amp which can run EL84's or 6V6's and the cab has 2x12
Tayden True Brit speakers.
Pete.
spikeymikey
PostPosted: Mon Aug 20, 2012 6:45 am    Post subject: Reply with quote
Just superb. Where'd he get the badges from ??
Dave_Mc
PostPosted: Mon Aug 20, 2012 9:10 am    Post subject: Reply with quote
oooh very nice, those EVAs are meant to be nice
awesome colour too
Max The Dog
PostPosted: Mon Aug 20, 2012 10:00 am    Post subject: Reply with quote
Thanks Dave.
The badges came from ebay Mike.
PostPosted: Tue Aug 21, 2012 3:58 am    Post subject: Reply with quote
Can't you use any old instrument lead with 6.5mm jack plugs on it?
Amp looks great BTW, and I like the idea of being able to use more than one tube.
Max The Dog
PostPosted: Tue Aug 21, 2012 9:09 am    Post subject: Reply with quote
Yes instrument cable is ok i have been told as long as the amp is not cranked up too much.(risk of fire) I am still waiting for UPS to arrive with the correct
one.
PostPosted: Tue Aug 21, 2012 10:19 am    Post subject: Reply with quote
one.
No no, screw that, burn your new amp to the ground! Wait for the right cable I think. Difficult as that may be...
I'd be interested to know what is different about the speaker lead that you get, compared to an instrument cable. Admittedly I've always used chunky figure 8 cable to connect speakers and not in any high power applications either, maybe only 20 or 30 watts solid state. Valve output stages are different because the speaker and the output transformer have to be matched together reasonably closely. The wrong cable could cause inductance problems that stuffs up the matching. Also this is a Class A amp isn't it - the output valve runs at full tilt all the time so I expect it's more important to keep it stable.
jawilluk
PostPosted: Tue Aug 21, 2012 11:12 am    Post subject: Reply with quote
The wire in instrument cable is not meant to carry the amount of current given out by an amplifier. This can result in the cable burning out like a fuse. Especially the braided shield wire.
Max The Dog
PostPosted: Tue Aug 21, 2012 1:34 pm    Post subject: Reply with quote
Yes thats exactly what I was told.
Mick51
PostPosted: Wed Aug 22, 2012 10:46 am    Post subject: Reply with quote
Yes, except that when a fuse burns out, it cuts off the current. And, this will too but.. YOWZA.. that's hard on the amp's OT.
jawilluk
PostPosted: Wed Aug 22, 2012 5:07 pm    Post subject: Reply with quote
Yes Mick51 and if the insulation in the cable melts then the output transformer can short out. Definitely use a proper speaker lead.
