Klusons
PostPosted: Thu Feb 09, 2012 3:16 pm    Post subject: Klusons Reply with quote
I?m planing on replacing stock Gotoh klusons in one of my Tokai Love Rock.
This time I?d go placing accurate parts.
Which one would you recomend me as the most accurate reproductions as possible?
Would I have to enlarge existing holes?
Regards,
Luis.
Skybone
PostPosted: Tue Feb 14, 2012 8:58 am    Post subject: Reply with quote
A lot depends on which model Love Rock and what style tuners you want to replace them with.
If your Gotoh's are the "plastic tulip" buttoned variety, then a set of Gotoh SD90's are the OEM tuners, and fit straight on without any messing around.
In fact, any Gotoh/MIJ/MIK/MIE/MIC tuners should fit straight on (IIRC - 10mm dia hole).
You would only get "problems" fitting anything made to US spec dimensions, as they use imperial measurements (fractions on an inch).
I replaced my stock tuners a few years back with standard SD90's, and they're still working fine.
http://www.myspace.com/misericordedoom
http://www.misericordedoom.com
