please help me identify Greco LP
thickey1983
PostPosted: Wed Jun 22, 2011 3:19 pm    Post subject: please help me identify Greco LP Reply with quote
Hello all,
can anyone please help me identify what model I have? I believe it's from 1980 according to the serial number; 0 3720
It has a long tenon neck joint. I don't know if the tuners are original but they're gotohs. The pickups I know are not original, and it has new pots and wiring, although I still have the original pots if that helps. It's a solid body, pretty heavy. No idea what kind of wood it is. When I bought the guitar I was told it was a 1980 Greco Les Paul Custom.
Here's a link to a couple pictures:
http://smg.photobucket.com/albums/v242/skateboarderth/Greco%20LP/
Any help is very very much appreciated, and let me know if you need more pictures or more info. Thanks a lot!
wulfman
PostPosted: Wed Jun 22, 2011 10:29 pm    Post subject: Reply with quote
That is a 1990 Greco, made in Japan. Nice guitar, it should be mahogany body with maple top.
PostPosted: Wed Jun 22, 2011 11:53 pm    Post subject: Reply with quote
If it ain't a bolt-on neck, it's a EGC-600 from 1990 like Harold says. TRC has been changed too.
thickey1983
PostPosted: Thu Jun 23, 2011 10:45 am    Post subject: Reply with quote
Thanks very much guys. No, it's not a bolt on. Unfortunately I'm hurting for money so I think I may have to sell it, so may I ask how can you tell? I'd just like to be able to back up the model number to any buyers.
Thanks again.
PostPosted: Thu Jun 23, 2011 10:51 am    Post subject: Reply with quote
The headstock gives everything away;
-Diamond inlay; that type of diamond inlay starts in 1989 (up to 1982 normal split diamond, from 1982 to 1989 flower type diamond).
-Greco logo: open O logo starts in 1982, somewhere during 1990 closed O again
- 0 serial number is either 1980 or 1990, because of previous 2 points it's 1990.
In 1990 catalog there's 4 customs (excl RR models):
-EGC900D; maple top/maho back; zebra SD APH-1 pups
-EGC700: 3pup custom
-EGC600: like yours with maple top/maho back, screamin' pups
-EGC480: bolt on neck, basswood body
So yours still could be the 900D but then you should original SD pups to go with it.
thickey1983
PostPosted: Thu Jun 23, 2011 10:58 am    Post subject: Reply with quote
Again, thanks so much. But how can you tell it's an EG-600? I'm really not familiar with Grecos at all, I had just seen this, played it, and fell in love. I know it does not have the fret-edge binding, although it does have a long tenon neck joint, and that's about the only two things I know of that would be factors in determining the model number.
PostPosted: Thu Jun 23, 2011 11:11 am    Post subject: Reply with quote
Actually without the original pups it's very hard to determine if it's a 900D or 600. To my knowledge none have feb. So if yours has a 3P top, it's most likely a 600, with a 2P top I would tend to think it's a 900D. But you can never be sure. Both have a poly finish btw.
thickey1983
PostPosted: Fri Jun 24, 2011 5:43 pm    Post subject: Reply with quote
So I took out the bridge pup to see if I could determine the number of plys in the top, and it appears one of the previous owners has tried to determine the same thing as part of the finish looks like it's been sanded away. To me it looks like the top is a piece of solid maple, but then again I don't know exactly what I'm looking for. Would you guys be able to tell how many plys there are in these pictures?
thanks again for all your help.
PostPosted: Sat Jun 25, 2011 12:31 am    Post subject: Reply with quote
Please correct me if I'm wrong but to me it looks like there's no center seam or seam at all in the pup cavity. That means either a 3P top or further off center seam (like on my RLC-65) 2P top. If so then I would be inclined to think it's e EGC-600.
If you to spot the seams the easiest way is to hold it in the light and look at it form different angles, you can spot them. front and back.
I think the sanding was done to determine if had a maho top, which it doesn't.
PostPosted: Sat Jun 25, 2011 8:11 am    Post subject: Reply with quote
Many 82-89 have the "correct" diamond.
PostPosted: Sat Jun 25, 2011 9:06 am    Post subject: Reply with quote
Pics please
PostPosted: Sat Jun 25, 2011 9:24 am    Post subject: Reply with quote
jacco wrote:
Pics please
Look in my P-bucket albums. you'll find.
PostPosted: Sat Jun 25, 2011 9:30 am    Post subject: Reply with quote
Link?
PostPosted: Sat Jun 25, 2011 9:55 am    Post subject: Reply with quote
I found it, went through your 1516 pics (you need to sort things out my friend) and it was a complete waste of time; only 1 cream custom from 1986 with the flower pot inlay, no 'correct' split diamond Greco customs there. Thanks.
PostPosted: Sat Jun 25, 2011 2:46 pm    Post subject: Reply with quote
Oh, that is only one out of 3 albums!
I have another one with 25k+ pics.
I'll look through it myself when I have time.
