Verdict: Solid or Veneer?
3pupLPC
PostPosted: Fri May 28, 2010 6:22 am    Post subject: Verdict: Solid or Veneer? Reply with quote
I recently picked up an OBG 59-reissue (FEB, etc) and am a little confused about it. I knew it did not have a scratchplate drilled, so I thought perhaps it was a special run, adn was hoping that it was a solid flame top. Once it arrived though and I pooped out the pups, I immediately said, "veneer"... but the thick cap is centered seamed and seams to be flamed itself. the top center seam seems just a tad off from the cap seam too... but the more I look, it looks as if the grain from the top matches the grain running through the sidecut.
It also has diagonal routing and a G-3xxx serial format (not G3, G-3). ANyone have any clues?
PostPosted: Fri May 28, 2010 7:36 am    Post subject: Reply with quote
thats a well matched veneer i think
mojo hobo
PostPosted: Fri May 28, 2010 12:03 pm    Post subject: Reply with quote
Congrats 3PUPPY
Beautiful OBG reissue...I guess that by the routing that is a early fujigen made OBG REISSUE...I cannot see the little shelf /ramp in the rear bridge pup cavity...which terada made ORVILLES & OBGs usually had..
How does she sound..how heavy is the beast...You have brought some very nice and seriously higher end MIJs recently 3puppy...GOOD STUFF!
MOJO HOBO
3pupLPC
PostPosted: Fri May 28, 2010 5:47 pm    Post subject: Reply with quote
Thanks Mojo
Haven't even played her yet, as I stuck in midst of ring change. I will weigh it once it is fully set up. On the lighter side tho... I'm thinking 8 and change.
3pupLPC
PostPosted: Fri May 28, 2010 5:49 pm    Post subject: Reply with quote
My thought too Mark ultimately... I would like to have seen the actual cap as it seems to have some interesting graining itself.
PostPosted: Sat May 29, 2010 6:34 am    Post subject: Reply with quote
yes it looks nicely grained, but the top is beautiful anyway
Cali Girl
PostPosted: Sat May 29, 2010 9:52 am    Post subject: Reply with quote
I wouldn't worry about it, sometimes it's just so hard to tell and people get into huge fights over it... looks good, plays good, keep it
3pupLPC
PostPosted: Sat May 29, 2010 10:03 pm    Post subject: Reply with quote
That's the problem... it has to go eventually. I just want to represent it accurately. But I will enjoy for a while first
japanstrat
PostPosted: Tue Jun 01, 2010 12:48 am    Post subject: Reply with quote
Diagonal routing and a G-3xxx serial = Terada.
Mono
PostPosted: Tue Jun 01, 2010 6:26 pm    Post subject: Reply with quote
I've seen a lot of LP inlays, but I have always admired those on the ObG 59 RIs. I would say they are better than the stock ones on Gibson Historics.
PostPosted: Thu Jun 03, 2010 5:30 am    Post subject: Reply with quote
heh when they don't fall out!!!
PostPosted: Thu Jun 17, 2010 3:22 am    Post subject: Reply with quote
+100000000000000000000000000000000000000000
