Rivera amp channel failure
imosdad
PostPosted: Wed Mar 24, 2010 11:25 am    Post subject: Rivera amp channel failure Reply with quote
One of the channels on my Rivera Chubster 40 is suddenly no longer working. I did a search here bit couldn't find anything relevant. Before I approach techie guys (of which I am not) does anyone have any idea if this could be as simple as a tube needing replacing or something more serious? Sorry if this is a totally stupid question.
Any help much appreciated!
Cheers
Dave
PostPosted: Wed Mar 24, 2010 11:40 am    Post subject: Reply with quote
The fact it has 5 ECC33 (12AX7) valves suggests to me that it has independent pre-amp valves for each channel, so it could well be something as simple as a duff valve!
Mick51
PostPosted: Wed Mar 24, 2010 11:45 am    Post subject: Reply with quote
Any noise when it let go? Snap, pop, etc? If there was, check the grid resistors on the main power tubes.
imosdad
PostPosted: Wed Mar 24, 2010 1:48 pm    Post subject: Reply with quote
Many thanks for the great replies. I'll investigate replacement valve(s) first. Love this forum!
Cheers
Dave
japaxes
PostPosted: Wed Mar 24, 2010 1:56 pm    Post subject: Reply with quote
dave if there are two preamp valves swap them over first (the working channel should then be the non working) then you will know if its a valve.
PostPosted: Wed Mar 24, 2010 2:12 pm    Post subject: Reply with quote
There are ecc83,s I would guess 1 pre-amp and 1 phase-inverter for channel 1 and 2 pre-amp and a PI for channel 2
