Pickup change?
Goto page 1, 2, 3  Next
tubuie
PostPosted: Fri Mar 19, 2010 5:45 am    Post subject: Pickup change? Reply with quote
Hi there guys!I've got an LS 85 (2007) model.Just wondering,do I really need to change the pickups?I mean,is it going to be such a big difference on the tone?A luthier told me "stick with the Tokai stock pickups otherwise if you really want to change the pickups you must be ready to buy some really expensive ones (like 250? each) to hear the quality of them,and not the common brands like S.D.,Dimarzio,Gibson,ect, they will not offer you anything better than your stock ones". Is that true?
Dad,I want that guitar,NOW!!!
PostPosted: Fri Mar 19, 2010 5:51 am    Post subject: Re: Pickup change? Reply with quote
"Do I really need to change the pickups?"....... that's entirely up to you. Are you unhappy with them? What are you looking for in terms of tone and output - rock, blues, out of phase, crunchy, mellow, etc.
Stock MKII pickups are great but everyone is different - I've never swapped out any of mine - yet I have replaced Gibson pickups with Seth Lovers........ go figure. You can certainly tweak your amp settings to fine tune your tone and you can do alot with your tone / volume settings on your guitar
tubuie
PostPosted: Fri Mar 19, 2010 6:01 am    Post subject: Reply with quote
Ok!The thing is that the stock pickups are pretty decent,but they don't have four conductor wiring that I was looking forward too.I really want to have more tone versatility for coil splitting.So, what do you think? p.s. I play rock,hard rock,blues
PostPosted: Fri Mar 19, 2010 6:16 am    Post subject: Reply with quote
Rock & hard blues, you would hardly ever use the coil-taps, IMO coil-taps never really work well enough to make them useable anyway.
tubuie
PostPosted: Fri Mar 19, 2010 6:23 am    Post subject: Reply with quote
I feel the need to make my guitar more twangy some times to get that sort of a P-90 tone out of it!Thats why I was thinking for a coil splitting thing!
PostPosted: Fri Mar 19, 2010 8:10 am    Post subject: Reply with quote
Maybe you could put that humbucker sized P90 in the bridge or neck position, or maybe even try a pair of them?
Fralin does a couple, called P92 and Twangmaster, have a look:
http://www.fralinpickups.com/humbuckers.asp
PostPosted: Fri Mar 19, 2010 8:13 am    Post subject: Reply with quote
Yup.... fits right into the humbucker routing.
Diamond
PostPosted: Fri Mar 19, 2010 9:02 am    Post subject: Reply with quote
Your luthier is a very clever man, listen to him.
PostPosted: Fri Mar 19, 2010 9:07 am    Post subject: Reply with quote
Very true, the stock tokai pickups are right up there with duncans etc.
LuBee
PostPosted: Fri Mar 19, 2010 2:02 pm    Post subject: Reply with quote
If you want the best of both worlds humbucker and p90/single coil when split, you could try something like Seymour Duncan P-Rails.
http://www.seymourduncan.com/products/electric/humbucker/progressive/prails_shpr1/
http://www.seymourduncan.com/products/electric/humbucker/prails_hot/
PostPosted: Fri Mar 19, 2010 2:12 pm    Post subject: Reply with quote
LuBee wrote:
If you want the best of both world humbucker and p90/single coil when split, you could try something like Seymour Duncan P-Rails.
[urlhttp://www.seymourduncan.com/products/electric/humbucker/progressive/prails_shpr1/[/url]
[urlhttp://www.seymourduncan.com/products/electric/humbucker/prails_hot/[/url]
LuBee, have you tried the P-Rails? Sound like a great idea, would be good to know if they deliver!
PostPosted: Fri Mar 19, 2010 2:15 pm    Post subject: Reply with quote
I looked at those when they came out - it did seem like the Holy Grail - HB, P90 & Strat all in one. But...to get all the sounds you need a 3 way mini-toggle, a push-pull pot will only give you two of them, which kinda misses the point. But it's an intriguing idea. Anyone tried them?
LuBee
PostPosted: Fri Mar 19, 2010 2:24 pm    Post subject: Reply with quote
Never tried them personally but have seen some pretty good videos.
The first is from Frank Falbo of SD http://www.youtube.com/watch?v=fZhJXcSVnfs&feature=related
The next are from a guy off the SD forum
http://www.youtube.com/watch?v=9q9VkER0dmw&feature=related
http://www.youtube.com/watch?v=pbDVlvyYry4&feature=related
http://www.youtube.com/watch?v=xSJ7D9IXfrg&feature=related
PostPosted: Fri Mar 19, 2010 2:37 pm    Post subject: Reply with quote
Thanks LuBee, I'll check them out later, off out for a beer now
Mike, what about a 3-way rotary switch in place of a tone control, and re-wire so you have a master tone?
PostPosted: Fri Mar 19, 2010 4:20 pm    Post subject: Reply with quote
Well that's fine if you know where to get a 3 way rotary switch. But anyway that wouldn't help if I fitted one to the neck position of my Tele - nowhere to put the 3 way switch.
Page 1 of 3
