Effects Pedal Repairs
LuBee
PostPosted: Thu Sep 17, 2009 4:16 pm    Post subject: Effects Pedal Repairs Reply with quote
The LED has packed up on my MXR Carbon Copy (everything else seems ok with the pedal) and I'd like to get it repaired.
Can anyone recommend somewhere where I could send it or does anybody on the board repair pedals?
Cheers
Lu_B
PostPosted: Thu Sep 17, 2009 5:01 pm    Post subject: Reply with quote
I would just pull the led out, take it to an electronics store, buy a new one and replace it myself....its only a bulb.
Ozeshin
PostPosted: Thu Sep 17, 2009 6:27 pm    Post subject: Reply with quote
I'm with Mick...just a quick solder job..old one out/new one in.
AND...I'd switch it to the new style Blue bulbs...gives it that "modern" look...everything seems to have Blue lighting these days
Diodibuh
PostPosted: Fri Sep 18, 2009 12:34 am    Post subject: Reply with quote
yes, blue is in
just be careful to remember how was connected - LED has + and - connectors
Griff
PostPosted: Fri Sep 18, 2009 12:59 am    Post subject: Reply with quote
Lubee,
if you haven't soldered before, I can do it for you. I'm near Oswestry in Shropshire, so I'm not far away.
I'm not guaranteeing that there's nothing wrong except the LED, though, and you'll get a full refund if it doesn't work, cos there's no charge.
PM me for contact details, if you're interested.
PostPosted: Fri Sep 18, 2009 4:26 am    Post subject: Reply with quote
While we're problem solving here, any idea where I can get my Tom Tom sat-nat fixed? It's getting temperamental about recharging, seems like a dodgy connection on the charger.
Griff
PostPosted: Fri Sep 18, 2009 4:43 am    Post subject: Reply with quote
It isn't easy fault-finding remotely, but it's most likely a frayed wire or poor solder joint in the charger leads, as they get pulled about a bit. I don't have a Tom-Tom (I forget what my satnav is called), so I'm assuming the charger arrangement is similar to mine. If you've got any sort of continuity tester or multimeter, check the lead continuity while wiggling the connections.
If you have a friend with a TomTom, you could borrow his charger lead and see if that sorts the problem. If it does, then you could always get a replacement or have a go at repairing it.
If it's an older unit, maybe the rechargeable battery inside is becoming geriatric. I bet there will be someone in the London area on here who'll take a look at it for you.
fury_dice
PostPosted: Fri Sep 18, 2009 6:49 am    Post subject: Reply with quote
They have blue LEDs from birth
