vikingblues
Active member
My LC95 was nicely set up for me with as low an action as could be and the recommended practice applied of strings nearly touching the back of the bridge frame on their way to the tailpiece.
The bridge is around 3/16" height off the body and the tailpiece is around 2/16" height. I believe some people say there is a tone advantage to be had with the tailpiece screwed down to the surface of the guitar body.
Obviously if I did this and nothing else the strings would touch the back of the bridge frame with horrible reesults to the tone and an increased danger of the bridge collapsing at some point.
If the right string angle could be maintained when lowering the tailpiece by top wrapping the strings, does anyone think it would be worth trying this when I next change the strings?
I guess if the result of the tailpeice being lowered and and the top wrapping was a shallower angle of strings from the bridge it could be bad for tone / sustain and may not be worth trying - I suspect it will be shallower but I will need to take time to sketch it out accuratley with proper measurements.
I am not bothered about the easier bending of strings if the angle is shallower - the bends are easy enough already with the steeper string angle.
I'm a bit wary of changing what is working so well, but I do know a lot of people are very keen on the top wrapping technique.
I would be interested in the views of the forum as you have way more experience than me on what can be done to the tone of quality guitars.
