Help me ID this Greco LP!
TonePort
PostPosted: Tue Sep 16, 2008 11:54 pm    Post subject: Help me ID this Greco LP! Reply with quote
ok, so im new in this forum but ive already searched the net for info about this LP i got from a trade, ive done my homework but still the info ive gathered was insufficient so here goes anyway:
first a little bit of history:
the previous owner is dead, and this was given to his nephews which they traded for my strat. some points that confuse me though:
1) the tuners (like all the hardware) are gold, but i replaced them as soon as got hold of it since the D peg was squinting;
2) one pup is covered while the other is open;
3) it says E77**** on the headstock so im pretty sure it's from the 1977 series;
4) there's this "Custom" inscribed on the truss rod cover;
i cant open up the bridge pup, only the beck pup does. rust has formed on the screws so it's quite difficult to unscrew the whole thing. ive also replaced the tailpiece and bridge and the knobs since one of the old knobs was missing.
at a local gear forum i stumbled upon this http://psyco.jp/greco/c06_02.html and my LP looks like the EG1000B, but someone said Custom models are EGC not EG.
here are some pics for reference:
notice the tuners
new tuners
new bridge and tailpiece, old thumbscrew
note the pickups
any help would be most appreciated. thanks guys!
Greco LP
imlikeajungle
PostPosted: Wed Sep 17, 2008 3:12 am    Post subject: Reply with quote
It helps to post pictures of:
the control cavity
the back of the headstock with the serial clearly visible
the cavity underneath the neck pickup to show the tenon + any seams in the wood (i.e. solid maple top, multiple pieces of the body)
the bottom of both pickups (though one seems to be not original)
'78 EG800PR Ace Frehley w/ Bareknuckle VHII
barburny
PostPosted: Wed Sep 17, 2008 7:51 am    Post subject: Reply with quote
Again its difficult to say with out the above info as stated by imlikeajungle
what i can tel from your info is
yes if your serial starts E77 then it is May 77
The C for custom came at the end. ie Eg600C
The B you thought stand for Black beauty
There was an Eg1000C but not sure if it was avalible in black
I think maybe yours could be a 800 or 600
the uncovered pickup I would say is a Greco pick up but lower end
get the pics up and maybe we can help some more or maybe some one would like to add/change what I have said
imlikeajungle
PostPosted: Thu Sep 18, 2008 5:26 am    Post subject: Reply with quote
I have those uncovered pickups with the metal 'ring' like you have in my EG800 (it has a sticker...) so it can still be an 800 like barburny says.
TonePort
PostPosted: Thu Sep 18, 2008 6:37 pm    Post subject: Reply with quote
oh thanks for the replies guys, i'll try to post pics as soon as i get home. i just opened this today
i have a strong hunch it is an EG1000C if not B since most specs fit the image as per the catalogue: knobs, tuners, gold hardware, scratch plate support (i wonder what that's called), and the engraved Custom on the truss rod cover.
i took a nosey inside the bridge pup cavity and man, was it full of dust. i tried to see the tenon but it seems there is none (maybe the dust had covered the crevices). i'll try to post pics later tonight. thanks for the help guys.
Greco LP
barburny
PostPosted: Fri Sep 19, 2008 11:43 am    Post subject: Reply with quote
I look forward to the extra pics
i would not like to do you out of a 1000 but my old Eg800pb(peter framton)
and im sure jungles frehely 800 have the gold hardware and custom printed on the TRC
the catalogues can be so misleading as greco often produced the models with different parts than the catalogues show
TonePort
PostPosted: Fri Sep 19, 2008 11:30 pm    Post subject: Reply with quote
thanks bud, im curious of the specs of the body actually and maybe an extra info would be most appreciated. when i first opened the control cavity the top looked like it has a solid cap and pancake on top, quite confusing actually. it's a bit heavy, like 5kg.
too bad ive got work even on a weekend, i cant post the pics needed. argggghhhhh!
Greco LP
TonePort
PostPosted: Sun Sep 21, 2008 6:52 pm    Post subject: Reply with quote
whew! the pics are in.
the control cavity. the tone pot for the bridge PU has been replaced. the 3 other pots are originals
Yamato ceramic pots (i think). pic shows the old pot and the replacement pot (both 500K) for the bridge tone pot
the dowel and tenon(?)
i cant see any tenon extending under the bridge pup. dont mind the green wire though, i used that for grounding the pups and switches to the control cavity and cover.
Greco LP
detroitace
PostPosted: Mon Sep 22, 2008 9:14 am    Post subject: Reply with quote
From the tenon shot, it looks like it's is a chambered one. Is that the case?
When you take a shower in space, you have to press the water onto your body to clean yourself, and then you gotta vacuum it off -- Ace Frehley
PostPosted: Mon Sep 22, 2008 10:29 am    Post subject: Reply with quote
What gives you the idea that it's chambered? The hole you see is the tunnel for the wires to the pickup selector switch.
detroitace
PostPosted: Mon Sep 22, 2008 2:44 pm    Post subject: Reply with quote
Well, the top looks a little thin to be a full cap and the tunnel looks a little
big and rectangular.
PostPosted: Mon Sep 22, 2008 3:27 pm    Post subject: Reply with quote
Yeah, I see what you mean....
barburny
PostPosted: Mon Sep 22, 2008 5:03 pm    Post subject: Reply with quote
Thats A chambered body
The tunnels for the wire is a lot bigger in chambered Grecos and quite common for a 77 model
PostPosted: Mon Sep 22, 2008 6:11 pm    Post subject: Reply with quote
If that guitar is chambered it is definitely not a "1000" model, it would be more like a "500" .
TonePort
PostPosted: Mon Sep 22, 2008 6:33 pm    Post subject: Reply with quote
thanks for the replies guys, that definitely helped you guys are right, it has a thin top (probably pancake) and large wire channels so it's probably chambered as you have stated (maybe that's why it resonates fully). given the specs found in this page http://psyco.jp/greco/c06_02.html (the first one in black) i wonder why the tuners, gold hardware, knobs and the TRC engraving matched. well, based on your suggestions, this page could've just fooled me hehe.
in which series does my Greco fit in?
Greco LP
