Calling all experts!
riprorin
PostPosted: Tue Jul 01, 2008 10:36 pm    Post subject: Calling all experts! Reply with quote
I'm wondering if anyone can tell me more about this guitar:
Head stock says Hondo II Professional - Made in Japan
Tuners have "Tokai" stamped on the back
Serial # is 0015551 which is stamped on the 4 bolt neck plate
It's a Tele copy, string through the body, wiith two pups. (Original pups have been replaced with American Fender Tele pups).
The body is three pieces, the neck appears to be maple, and the body is a light colored wood (the original paint was stripped off).
Any information about the date of manufacture, the manufacturers and the quality of this guitar would be greatly appreciated.
Thanks!
Ozeshin
PostPosted: Wed Jul 02, 2008 2:31 am    Post subject: Reply with quote
Even WITHOUT pics I can safely tell you that you have a frankenmongrel.
It's NOT a Tokai but it sounds more likely that somebody has bought a few tokai parts off ebay.
It's even doubtful that it's an actual HondoII...pics please..**sigh...it sux to have to keep reminding people to post questions WITH pics**
riprorin
PostPosted: Wed Jul 02, 2008 6:00 am    Post subject: Reply with quote
It's my fist time (here), so be gentle! Someone suggested that it was a Tokai Ghost.
Here are some pics.
Thanks!
Ozeshin
PostPosted: Wed Jul 02, 2008 7:31 am    Post subject: Reply with quote
Looks pretty decent...you'd have to remove the neck and look for a stamp...same for the pickup routes under the pickguard.
PostPosted: Wed Jul 02, 2008 8:16 am    Post subject: Reply with quote
As far as I know Tokai did manufacture at least some of the "Hondo II Professional" range, it seems reasonable that some may have had Tokai stamped tuners. Oze, what makes you think it's a 'Frankenmongrel'? I'm sure it could just as easily be a Tokai made Hondo.
As for dates and stuff, I'm sure this has been discussed before, a search should show something up.
AlanN
PostPosted: Wed Jul 02, 2008 9:38 am    Post subject: Reply with quote
That serial plate looks very Tokai. Not that they're that unique to begin with, I know, but it certainly matches with the older Tokais I have (even the chunky screw heads)!
riprorin
PostPosted: Wed Jul 02, 2008 8:29 pm    Post subject: Reply with quote
So if it's made by Tokai it's probably fairly decent quality?
Any idea what the value is?
riprorin
PostPosted: Wed Jul 02, 2008 10:28 pm    Post subject: Reply with quote
The head stock is a little sifferent but otherwise it looks just like this Tokai Breezy Sound.
http://imageevent.com/chingo123/july2008/tokaibreezytelebutterscotch3358
javelin70
PostPosted: Thu Jul 03, 2008 5:37 am    Post subject: Reply with quote
If you look at the end of the neck and in the control cavity you'll probably find the typical Tokai codes (like 6=8 for example). Tokai made the Hondo Professional guitars so the quality should be excellent. That headstock was used for both the strat and tele model it seems. Also, it's the same headstock design that have been used on some Tokai models, for example the MAT strat.
