Fender Vibroverb 63 Re-issue
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Dave_Mc
PostPosted: Wed Feb 18, 2009 11:01 am    Post subject: Reply with quote
sorry to hear about the speaker- i have no idea how to fix that. i guess if you're considering ordering another one anyway, you might as well try john's advice to see if that works...
PostPosted: Mon Feb 23, 2009 8:24 am    Post subject: Reply with quote
It looks as though John was right. I did a patch repair with 8 or 9 pieces of black tissue paper & some watered-down PVA glue. Work in progress:
Drying:
Finished repair, 24 hours later:
24 hours after the repair, the amp was run for over an hour with the volume set on 10! It seems to have been a complete success, so I have cancelled the new speaker. I'm surprised, but very happy.
Thanks to John for his excellent advice.
PostPosted: Mon Feb 23, 2009 8:34 am    Post subject: Reply with quote
Glad it worked out Mike, you should always listen to me, I'm not often wrong!!
Dave_Mc
PostPosted: Mon Feb 23, 2009 9:42 am    Post subject: Reply with quote
sweet, glad to hear it worked out.
PostPosted: Mon Apr 06, 2009 7:48 am    Post subject: Reply with quote
I have had a yard of replacement grille cloth for the Vibroverb on order since January from www.guitar-parts-and-spares-uk.com . Apparently Fender have changed their distributor, & nothing is coming in. This is a real pain.
Can anyone help me with an alternative source for Fender grille cloth? I have suggested that the supplier I have ordered from tries Fender Japan, but I have no idea if they have anything suitable.
Failing that, can anyone suggest a close alternative I could use until I get the proper cloth? The trouble is that brown Tolex is quite a rare colour, & it's hard to get something that looks right.
Any ideas? Here's the cloth I need to replace.
Dave_Mc
PostPosted: Mon Apr 06, 2009 10:50 am    Post subject: Reply with quote
tube town maybe ( www.tube-town.de ) ? i've never ordered from them, just heard of them... they're based in germany. there are probably other places in the UK which'd be worth looking at too, but I haven't heard of them...
AlanN
PostPosted: Mon Apr 06, 2009 12:11 pm    Post subject: Reply with quote
That doesn't need replacing, Mike - looks just right!
PostPosted: Mon Apr 06, 2009 12:16 pm    Post subject: Reply with quote
It did then, it doesn't since the speaker got damaged & repaired.
AlanN
PostPosted: Mon Apr 06, 2009 12:18 pm    Post subject: Reply with quote
Ah, the tear got bigger? Erk.
Cream would work. It'll look different, but it'll work fine. If you want any mock-ups give me a shout; it's the work of seconds to colourise the grillcloth in photoshop.
PostPosted: Mon Apr 06, 2009 12:20 pm    Post subject: Reply with quote
Is it? So would this one (from the site Dave posted) work? It looks too bright, but it's the nearest they seem to have:
http://www.tube-town.net/ttstore/product_info.php/info/p2129_Grillcloth-Fender-Beige-Brown-SAMPLE.html
AlanN
PostPosted: Mon Apr 06, 2009 12:26 pm    Post subject: Reply with quote
Don't worry, it'll look much darker when in situ - see this example:
http://ecx.images-amazon.com/images/I/417YrbHM2VL._SL500_AA250_.jpg
This photo shows the cloth laid down and photographed with a flash, and the cloth in place on an amp.
Edit: another example of beige-brown in place:
http://www.vintage-vibe.net/Images/Projects/THD_Lookalike.jpg
AlanN
PostPosted: Mon Apr 06, 2009 12:30 pm    Post subject: Reply with quote
Just checked what yours is supposed to be - it's wheat (same as brown-beige). Should be a perfect match, but it'll look a bit strange at first because it's so new (especially if the tolex has discoloured a bit). Give it time though.
AlanN
PostPosted: Mon Apr 06, 2009 12:43 pm    Post subject: Reply with quote
I suspect your camera has done your amp a disservice in your original pic and overdone the colour; there's an unnatural purple tinge to things. That said, even this might be too bright for what it'll finally look like:
PostPosted: Mon Apr 06, 2009 1:19 pm    Post subject: Reply with quote
Blimey, how did you do that? It must be witchcraft...
This is the most recent photo I have, for comparison purposes. So you reckon it's a good match then, bearing in mind that the original cloth is (I assume) over 15 years old?
AlanN
PostPosted: Mon Apr 06, 2009 1:57 pm    Post subject: Reply with quote
Absolutely. And once you've done a few gigs with it, it'll soon lose that too-new vibe. There are aging techniques for these too - staining with coffee and tea etc - if you can be bothered!
Page 7 of 9
