1978 EG800PR questions
imlikeajungle
PostPosted: Tue Apr 08, 2008 4:44 pm    Post subject: 1978 EG800PR questions Reply with quote
First of all: thanks for all of the information I have already gathered thanks to this great forum & the links posted here, and the websites of the forummembers! It made me pull the trigger on an '78 EG800PR & I love it!
I have a few questions as I am a bit confused about the specs.
- if I understand correctly this was a middle-range model?
- the specs from japanstrats post from the 1980 Catalog say the following:
EG800PR (Ace Frehley 3 pickups): Mahogany one layer body, Maple two piece top, Red Sunburst finish, Mahogany one piece neck, Ebony Fingerboard, U-2000 pickups.
Mine has a two-piece body (very well matched though). Is this because it is a '78 or are there more of these discrepancies? Also, did Greco do any weight relief? The guitar feels absolutely massive, just wondering.
- are the pickups original? As the (crappy) picture shows, the cream 'covers' are mounted in a metal 'frame'? The code on the bottom says, I believe, 240408. Nothing else. All three have the same code & look the same too. Does anyone know which pickups these are?
- how is the hardware on these models? I don't have much experience swapping hardware but I believe I read somewhere here that the pre-80 models had hardware problems? The tuners for example don't feel too secure but I am holding back to start changing things on a guitar this age.
- does anyone know which woods were used for neck & fingerboard? And which material for the inlays? Is it all the same as in the '80s?
- some extra info:
* no fret binding
* braided wiring
* dowel tenon
* 2 piece top
* 2 piece back
* I believe 3 piece neck
* trussrod cover says 'custom', written vertically in capitals
* very heavy
Lastly, could anyone give me an indication of the European market value of this guitar? Just wondering if I got ripped off or not
Thank you very very much!
Kindest regards,
B.
imlikeajungle
PostPosted: Wed Apr 09, 2008 11:36 am    Post subject: Reply with quote
Did I do anything wrong or are my questions just unanswarable?
PostPosted: Wed Apr 09, 2008 12:45 pm    Post subject: Reply with quote
I?m not so sure EG-800 being 2 pieces body made but a pancake body,but I could be wrong, my Greco?s long gone.
imlikeajungle
PostPosted: Wed Apr 09, 2008 1:32 pm    Post subject: Reply with quote
It looks like a two-piece but I'll check again...
EDIT: reading the other topic, would you say this one has a maple neck?
20 century boy
PostPosted: Wed Apr 09, 2008 1:47 pm    Post subject: Reply with quote
Many Greco from the 70's have those metal frames so almost certain it's original. I have one with those frames too.
nankurunai sa!
imlikeajungle
PostPosted: Wed Apr 09, 2008 1:51 pm    Post subject: Reply with quote
So it would still be the U1000s? There is nothing stamped in the pickups...
joukov
PostPosted: Wed Apr 09, 2008 2:34 pm    Post subject: Reply with quote
My 800PR had fret end binding, are you sure that is not 600 model then?
You can find 1978 catalog scans here somewhere, I think. Pick ups should be U2000s in 800PR and U1000s in 600 if I recall right.
imlikeajungle
PostPosted: Wed Apr 09, 2008 4:41 pm    Post subject: Reply with quote
There is a sticker on the back saying 800... I'm not sure if that guarantees that it actually is a 800? I have also tried to find '78 scans but can't find them...
PostPosted: Wed Apr 09, 2008 4:52 pm    Post subject: Reply with quote
You didn't look very far
I posted a link in the next thread doen to a 79 catalog with a EG800PR in there
http://brochures.yokochou.com/guitar-and-amp/greco/1979/en_index.html
imlikeajungle
PostPosted: Wed Apr 09, 2008 5:02 pm    Post subject: Reply with quote
I had seen that, but it is '79, not '78
Because of the completely different headstock I didn't think the rest of the specs would be the same?
PostPosted: Wed Apr 09, 2008 5:04 pm    Post subject: Reply with quote
Sorry I thought they would be the same, I cant read the specs anyway
imlikeajungle
PostPosted: Wed Apr 09, 2008 5:08 pm    Post subject: Reply with quote
I am more confused now, then I was before
So with it being an 800 the pickups should be U2000s, even though they just have the code written on them, nothing else.
But for the rest... Brr! Any concluding info would be great, especially about the woods used...
20 century boy
PostPosted: Thu Apr 10, 2008 1:41 am    Post subject: Reply with quote
yes. i think it's normal.
Quote:
Greco and Ibanez Nisshin Onpa (Maxon) pickup serial number format consisting of 6 numbers from 1977 to 1982.
First number = Nisshin Onpa (Maxon) pickup code (1, 2, etc)
Second number = Year (9=1979)
Third and Fourth number = Month (01=Jan ... 12=Dec)
Fifth and sixth number = Day of Month (01-31)
in those years they did but the guitars could still be very heavy.
main problem on the hardware with Greco guitars is esthetic. Often, the chrome tends to crumble away. But it's a good very functionnal hardware. And it also depens on where the previous owner used to live in Japan ( there's area worse than others) and how it was taken care of.
nankurunai sa!
imlikeajungle
PostPosted: Thu Apr 10, 2008 4:06 am    Post subject: Reply with quote
Great, thanks for all that. I'll have a closer look at the body when I get the chance to see if it is pancake or not.
Can I also be semi-sure that the neck is maple?
joukov
PostPosted: Thu Apr 10, 2008 11:00 am    Post subject: Reply with quote
My Greco EG-800PR '78 was aroung 4,7 kg so it was quite heavy, thick maple cap on mahogany. You should be able to find the pics here on the forum.
Here are a couple of links for EG800PR specs, not quite sure how reliable they are:
http://www.nexyzbb.ne.jp/~kt-factory_2007/GUITARS/eg800.html
http://kiya-hen.net/equip/22.html
There used to be a similar page like this, http://www.sf.airnet.ne.jp/~shake/greco/catalogue/1978/1978.html but you were able to click the thumbnails and see the fullsize catalog.
