Value of 2005 Tokai LS-150?
magentaplacenta
I might be doing a trade deal of a supposed 2005 tokai LS-150, what would you all say the market value of that Tokai is and are there any signs I should specifically look for that indicates it is indeed a 150 -vs- a lower model?
I've received a first batch of photos, it looks in very good condition and I've requested the following photos:
front and back of headstock
neck and bridge pickup cavities including a shot of the maple top on the mahogany body (to see if flame is a veneer)
bottom of both pickups
electronics cavity
Also inquired as to state of frets and if it has the original case.
I found the following photo posted in October of 2005 at http://guitars.co.uk/cgi-bin/bulletinboard_cgi/ultimatebb.cgi/ubb/get_topic/f/1/t/007019/p/1.html
Check this post :
http://www.tokaiforum.com/viewtopic.php?t=8992&highlight=150
Without disassembling the guitar things you can easily check are :
Nitro finish - it should smell like nitro;
Fat 50s neck;
lightweight ally tailpiece - tap it ! they feel lighter;
CTS pots - c/w stock Japanese units they feel stiffer with more resistance;
One piece body - check for joint lines at the edge of the body;
I think they were all or mostly made in 2005 - so a 05 serial no is good;
Check the control cavity for braided wiring and the sprague orange drops.
As for value - the new price if you can find them is around ?750 - used value depends on what it is worth to you.
Hope this helps.
Value was Yen 150,000.-- without tax in 2005. Take inflation and you'll end up at around Yen 168,00.--. Add cost of transport from Japan to Europe or US being roughly ? 100.--. Then add customs duties and VAT.
Easy.
Rupert
Thanks guys. I'm guessing the deal won't happen as I haven't heard back and he was very prompt in response/photos in previous emails.
