blue-audio
- Joined
- Feb 19, 2008
- Messages
- 6
- Reaction score
- 0
I acquired this Goldstar sound recently. It has been ****ed around with a bit, so I'm having trouble identifying it exactly.
The tuners are stamped "Deluxe" - I haven't bothered putting a picture up. Photo of the headstock follows, the locking nut is, it goes without saying, a later addition.
The neck markings are pretty hard to read - it seems to say 10-?
If there are any body markings, they can't be read, as a previous owner has painted the entire body cavity with some kind of conductive paint for some reason. I can't chip it off to see. You can see it on the lefthand side of the picture of the neck cavity. I assume that the shim has been added later. The finish is a slightly metallic blue, which has discoloured to slightly greenish where it has been exposed to the light.
The tone controls have been completely bypassed, but as far as I can see the pots are original. I'm pretty sure the selector switch has been replaced. The wires are plastic-covered.
The pickups are pictured below. I haven't bothered posting a picture of the bridge as it has been replaced with a Schaller.
Serial number is L145**
