Wood type?
stringman66
PostPosted: Sun Feb 17, 2008 11:45 am    Post subject: Wood type? Reply with quote
Hi, I'm starting a new project guitar with a Fernandes body. Can any of you wood gurus identify this wood type for me?
TIA
Jeff
PostPosted: Sun Feb 17, 2008 1:01 pm    Post subject: Reply with quote
Well it's not ash, so it's probably alder or (since it's Japanese, I assume) basswood. The grain looks right for alder, and that's the most common Strat body wood.
MIJvintage
PostPosted: Sun Feb 17, 2008 1:49 pm    Post subject: Reply with quote
Even though it is most likely alder, it is difficult to tell from a photo.
Grain & color both must be taken into account.
Grain looks like it could be alder or ash but the color in areas is almost white, like ash.
what was the (original) finish on the body?
PostPosted: Sun Feb 17, 2008 1:54 pm    Post subject: Reply with quote
Erm, red?
MIJvintage
PostPosted: Sun Feb 17, 2008 2:07 pm    Post subject: Reply with quote
but what is the darker color, under the red?
If you look, there is a darker color, nearly black, at the inside edge of the red, and the trem route has a yellow, as a sunburst would have
I can assume anything but I would rather ask, and not be percieved as a know it all.................
stringman66
PostPosted: Sun Feb 17, 2008 2:35 pm    Post subject: Reply with quote
Thanks for the feedback. I think the first layer (yellow) looks like some kind of sealer. Then blackish then the thick red. I guess it could have been a sunburst.
It's a 90's fernandes MIJ. Not their best era for strats so I took the belt sander to it. I'm going to paint it black and try to make the black Gilmour guitar.
I was just really curious what was underneath, now I know it's not particle board or anything like that.
PostPosted: Sun Feb 17, 2008 2:39 pm    Post subject: Reply with quote
Why do you say that?
stringman66
PostPosted: Sun Feb 17, 2008 2:52 pm    Post subject: Reply with quote
That's just been my experience, though limited. Seems like they went to cheaper electronics and the ugly headstock. Just my opinion, what do I know.
MIJvintage
PostPosted: Sun Feb 17, 2008 2:58 pm    Post subject: Reply with quote
Grain & weight can also provides clues to the type of wood
If the grain is fairly closed I would lean more toward guessing alder but if the grain has a more open type feature, then it could be ash
Strat bodies made from alder usually run in the 4.0 to 4.5 lb. range
Depending on the type of ash lumber, Strat bodies made from ash usually range from 3.25 lb. for light weight swamp ash to 5.5 lb. plus for hard ash examples
From my own experience, I would usually judge on openess of grain & coloration of the wood
PostPosted: Sun Feb 17, 2008 4:57 pm    Post subject: Reply with quote
Hi all, I'd bet that is Ash, probably sen Ash, which is heavier than American Ash, i have seen figured alder ,but to me that is some type of Ash, and the darker colour is the red burnt by a sander, when an electric sander is used on red it turns it almost brown from the heat it creates.
japanstrat
PostPosted: Mon Feb 18, 2008 12:36 am    Post subject: Reply with quote
Probably Sen Ash.
http://www.mijguitar.com/Templates/Guitar%20Body%20Woods.htm
