orvilles vs gibson LP standard
Discussion area for Orville and Orville by Gibson guitars
Sir Punk
Post by Sir Punk » Sun Jul 20, 2008 9:47 pm
so I am wondering what are the differences between a Gibson LP standard and an Orville/OBG.
The standard's have fret binding and it seems to me that Orville don't.
Also some Orville have 2 piece necks but I don't know if that's true for standards.
what else?
Post by leadguitar_323 » Mon Jul 21, 2008 2:20 am
Orville and Orville By Gibson are two completely different guitars. Only the OBG reissues have fret edge binding they also have the long neck tenon and are generally better built guitars than the gibson standards, the obg's have a much better and more stable neck joint.
Sir Punk
Post by Sir Punk » Mon Jul 21, 2008 7:25 am
http://cgi.ebay.com/Orville-by-Gibson-L ... dZViewItem
it seems to me that this has not fret edge binding. But it's hard to see.
Post by JohnA » Mon Jul 21, 2008 7:33 am
There are two different Orville by Gibson models, the 'standard' and the 'reissue'
The one in the listing is a standard, has 'standard' on the truss-rod cover and no FEB. The reissue's have a blank cover and FEB, either way, fret-edge binding is really only cosmetic, an OBG standard will still be a great guitar!
Sir Punk
Post by Sir Punk » Mon Jul 21, 2008 7:47 am
ok I gotcha. so OBG standard are somewhat comparable to gibson standard?
and do both reissue and standard OBG have more stable neck joint than a gibson? is what you say based on your personal experience?
Post by JohnA » Mon Jul 21, 2008 8:05 am
Both the standard and the reissue have a long tenon neck joint, whether or not this contrubutes much to the tone, or the stability we could all have a week long debate and not reach a conclusion :wink:
One thing a long tenon is, is historically correct, just like a real '58
Really the only difference is the FEB, a modern Gibson Standard has FEB so really an OBG reissue would be closer in outward appearance to a modern standard, but in terms of construction both a OBG standard and a reissue are closer to a real '58 Les Paul.
Oh, from personal experience I've never had any 'stability' issues with a modern Gibson neck joint, but the best overall sounding and playing Gibson I ever had was an OBG :D
Sir Punk
Post by Sir Punk » Mon Jul 21, 2008 8:21 am
so are you telling me that gibson standard have short tenon?
the only problem is that the prices of OBG are almost as much as a used standard. I wish I woke up a few years earlier :D
Post by JohnA » Mon Jul 21, 2008 8:33 am
Sir Punk wrote:so are you telling me that gibson standard have short tenon?
Yes, a standard has a short tenon, and also more than likely a 'weight relieved' body which is a fancy way of saying it has holed drilled in the mahogany!
Yes an OBG reissue is almost the same price as a Standard, but it's just about Historic spec apart from the 2-piece back. I would say get an OBG reissue in preference to a standard. The last few standards I've picked up in my local shop have been pretty uninspiring, but if you can find a nice one, used, then that would hold it's value as much as the OBG.
japanstrat
Post by japanstrat » Mon Jul 21, 2008 8:52 am
The Terada made G serial regular OBG's can sometimes have separate neck heels (2 piece neck) on the lower priced OBG's. Terada also do this on some K Orvilles which isn't surprising seeing that a lot of the K Orvilles seem to be rejected G serial OBG's. The other difference between Gibson and Japanese guitars is that Gibson mostly use Honduras Mahogany (but that might have changed a bit recently) and the Japanese makers mostly use African Mahogany. I have Gibsons and Orvilles and the wood type difference means nothing to the sound IMO. Fret edge binding is like car power windows, not needed IMO.
Sir Punk
Post by Sir Punk » Mon Jul 21, 2008 9:31 am
http://cgi.ebay.com/1992-ORVILLE-BY-GIB ... dZViewItem
this has a medium tenon and it's a OBG. how come?
Post by JohnA » Mon Jul 21, 2008 9:54 am
Sir Punk wrote:http://cgi.ebay.com/1992-ORVILLE-BY-GIB ... dZViewItem
You got me there!! Hopefully japanstrat will be along soon :D
Sir Punk
Post by Sir Punk » Mon Jul 21, 2008 10:03 am
japanstrat
Post by japanstrat » Mon Jul 21, 2008 10:51 am
The G serial OBG's and the K Orvilles are made by Terada mostly from 1988-1993. Terada made them with different tenons, long, medium long, and medium. Terada also made some OBG's and K Orvilles with separate neck heels. FujiGen is the other OBG and Orville maker mostly from 1993-1998 and they use no letters in their serial numbers. All of the FujiGen OBG's and Orvilles have long tenons and I've never seen one with a separate neck heel.
Sir Punk
Post by Sir Punk » Mon Jul 21, 2008 11:01 am
could you guys give me some infos about the necks?
I'd like a 60's style neck. what kind of variety can I find among O or OBG. and is there a way to tell from the serial number or other details?
do any OBG have ebony fretboards?
3pupLPC
Post by 3pupLPC » Wed Jul 23, 2008 8:52 am
Sir Punk,
I went through several Gibson LP's over about a 10 year period a few years ago when I got back into playing and came to the conclusion that I just did not like Les Paul's. I jumped over soley to strat's and tele's. Fender Japan re-introduced me to MIJ quality which then got me into looking at OBG and Burny... turns out that I didn't dislike LP's- I disliked GIBSON LP's (numerous pieces from a '72 deluxe, a '81 Standard, an '02 Standard to name a few). Quality and workmanship range from "not-worth-the-??" to absolute CRAP.
IMHO, if you are shopping for a LP in the Gibson Standard price range- get an OBG. (same goes for SG's which are my main guitars now).
My rule of thumb to friends who ask-If you are shopping for:
Entry LP (Epiphone, etc) - buy an Orville instead
Gibson LP - buy an Orville by Gibson LPS instead (like the listing you posted)
historically accurate Gibson RI (ha-ha) - buy an OBG LPR, or if Customs are your thing an OBG '57 LPC (ebony board) instead.
And your question about necks, I think generally the LPS's lean more to a 60's profile. My LPR has a fatter 50's profile.
Villagers homepage has some great info... http://www.japanguitars.co.uk/Page%201%20history.html
Good luck.
