Burny Doubleneck...Jimmy Page
hunter
Pennsylvania
Hello,can anyone tell me anything about this.Just had to have it and hope its the real deal. :eek:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130194819922&ssPageName=STRK:MEWN:IT&ih=003
PICTURES ADDED:
http://s260.photobucket.com/albums/ii5/11099tech/
It's in the catalogues:
http://www.fernandes.co.jp/others/catalog/1981_01/13.html
Thanks Bart,will try to translate...very cool thanks :D
interesting the six string pups are uncovered .could mine be a diffirent year :roll:
Lookie here: http://www.fernandes.co.jp/others/catalog.html
Looks like the 79 catalogue may be the one I need to see.All versions shown have no p/u cover on 6 string.Info from prior owner says only swapped out pup,came original with covers :-?
Guitar has arrived.Surprised it has a serial no. 73007.Does this indicate its a 1977 or 1973 :-? .Prior owner stated VH1 pups,can anyone tell from pictures?Would sure appreciate any info someone may have.Body is 3 pice/necks are straight.Other than single coil installed it seems to be all original
Sorry can't tell you anything about it other than it's cool as F*** but you knew that :wink:
Nice guitar Im jealous!!
Thanks John,cant seem to put her down.Action sweet on both necks :D surprisingly light too,expected an anchor........m.i.j. even up close hard to tell if first digit is 1 or 7 but from catalogues I have seen the 81 had open coil pups on 6 string :-?.
I agree looks like 81 even in additional photo .Top of 1 has dark finish spot which was deceiving
:D
I have a fernandes 'electric sound research group' double neck for sale.
I'll post an topic in the classified section soon :)
Turns out the burny needs new toggle switches.Tried all the normal supply houses and no luck.Even called gibson and was told the neck selector is proprietary and would not name vendor :evil: they did say the pickup selector was standard right angle toggle,but the original has 4 posts for input of p/ups and 2 out. I believe standard has 2 and 2.Does any one know if that matters or maybe where I can buy exact replacements :eek:
The short 12 headstock and neck volutes make this a less attractive option... looks like they copied the 70's Gibson 6/12 rather than Jimmy's earlier model?
