RLC but what model #?
MIJvintage
PostPosted: Wed Nov 28, 2007 10:43 pm    Post subject: RLC but what model #? Reply with quote
.........have a Burny RLC here; 2 pc. maho body back, 2 pc. center seam maple top, 1 pc. maho neck, very THIN poly clear coat, VH-1 pups, gold hardware, under 9 lbs., superbly crafted Les Paul, completely original minus pick guard.........
..............obviously an RLC but anyone know what model # RLC?............thanks.............
burnyIII
PostPosted: Sat Dec 01, 2007 6:58 am    Post subject: Reply with quote
i do not know which model this beauty is, but i know it is one of the most beautiful LPCs I have ever seen ....
Do you sell it?
... just kidding, congrats to this super beautiful Paula!
Bye
b.III
Let there be Rock !
PostPosted: Sat Dec 01, 2007 9:32 am    Post subject: Reply with quote
1 piece neck? Surely it's a 3 piece neck?
MIJvintage
PostPosted: Sat Dec 01, 2007 10:39 am    Post subject: Reply with quote
1 pc neck (mahogany)
no added heel cap aka a true Gibby style 1 pc. neck
PostPosted: Sat Dec 01, 2007 10:44 am    Post subject: Reply with quote
What about those side pieces on the headstock? Surely they are glued on, which means the neck is made from 3 pieces of wood?
MIJvintage
PostPosted: Sat Dec 01, 2007 10:58 am    Post subject: Reply with quote
old, original Gibsons are made the same way, and I don't believe they are considered to have 3 piece necks.
Technically, you may be correct but in reality you are missing the point....................
PostPosted: Sat Dec 01, 2007 11:05 am    Post subject: Reply with quote
Am I? Sorry. My Gibson LP Special has those "wings" on the headstock, and I assumed that meant it had a 3 piece neck, since it's made from 3 pieces of wood! Obviously the terminolgy is more complicated than I realised.
f5joe
PostPosted: Sat Dec 01, 2007 3:04 pm    Post subject: Reply with quote
Gibson necks typically have wings. However, the necks are one piece at the same time.
This is a stunning guitar!
PostPosted: Sat Dec 01, 2007 7:35 pm    Post subject: Reply with quote
Hi guys, They are referred to as 1 piece necks, its the headstock that has the wings. Necks in more than 1 piece have clearly visible joins the length of the neck. Hey Mike it sounds like you need to buy a Les Paul if only to help you in your quest for knowledge.
cheers Mick
MIJvintage
PostPosted: Sat Dec 01, 2007 11:35 pm    Post subject: Reply with quote
It is a looker but it plays & sounds 10 times better than it looks
PostPosted: Sun Dec 02, 2007 5:49 am    Post subject: Reply with quote
cheers Mick
Mick,
I have 2 already! A 97 Gibson LP Special with P100s, and a Korean Tokai LS48. Neither get played much, they just don't really fit what the band does. I'd love to try a Tokai Goldtop with P90s, but I doubt if I'll find one with a slim enough neck for my liking.
burnyIII
PostPosted: Thu Dec 06, 2007 1:53 am    Post subject: Reply with quote
It is cleaarly a one piece neck because the neck is one piece.
The headstock is not one piece, but the headstock is not the neck. One piece headstocks are not too usual at Les Pauls Customs...
Also many Standards do have headstock wings ...
Bye
B.III
Let there be Rock !
MIJvintage
PostPosted: Fri Feb 29, 2008 4:56 pm    Post subject: I Guess It Doesn't Matter.............. Reply with quote
