Overdrive pedals
Eigil
PostPosted: Sat Feb 15, 2003 9:00 am    Post subject: That it is! Reply with quote
The Carl Martin pedals are built to last forever, have the best posible cirquits, and have their own built in powercord. Besides they sound amazingly transparent, with great warmth!! Neat aye? The Carl Martin effects should be available in the US, since I have read about Americans using 'em. You should also check out the Compressor/Limiter - Best there is they say!! It is as good as a Tuberack compressor, and is perfect for both studio and live. That will be my next Carl Martin purchase! I now own the "Chorus XII" (best I've heard!!)
Regarding that Pedalman Tubescreamer, they are butique, and I believe you must speak to the pedalman himself. I believe there are just a few of them left, so hurry up!
Eigil Korsager
loverockerUK
PostPosted: Sat Feb 15, 2003 2:49 pm    Post subject: Reply with quote
null
Watto
PostPosted: Thu Apr 03, 2003 7:59 am    Post subject: Reply with quote
My favourite overdrive is the HOTCAKE. They're handmade in New Zealand www.melmusic.com.au/hotcake/hotcake.html and true bypass,
my second favourite is the maxon od808 which i've added the rare texas instruments 4558p op amp and the fulltone 9 pin true bypass switch
thirdly is my Ibanez ts9/808 brown mod
Watto
Proud Les Paul Reborn Owner
ScottA
PostPosted: Sun Sep 04, 2005 10:54 am    Post subject: Reply with quote
Somebody mentioned Keely earlier:
I've got an Ibanez TS9 with the "808 mod plus" from Keely. It's really nice. I A/B'ed it against my neighbor's stock TS9, and it was much more transparent, and without the mid boost that TS9's usually have. Nice and warm. Worth the money.
But all, that said....I don't even have it on my board right now. I had to make room for a compressor. I get all my distortion out of my amp. Best way to go!
Blues Junior
PostPosted: Thu Nov 10, 2005 10:56 am    Post subject: Reply with quote
I tried Keeley BD-2 and SD-1 (which i own) and BD-2 makes my Laney LC15R breathe, it has a great sound! The SD-1 is much mid ranged, and it's a great Hard rock overdrive, i love it! Now, im buying a blues overdrive, and the finalists are Barber LTD, and the Keeley BD-2. I woudn't ever consider Barber, but when i read the rewiev on Harmony Central, i thought, i should give it a try. The real problem is, i can't try it anywhere, so maybe some one of you guys tried it, and he could say something about it!
FordFanJpn
PostPosted: Thu Jun 15, 2006 2:06 pm    Post subject: OD Reply with quote
I build my own amps based on the Dumble ODS, so generally I don't need an OD pedal. However, sometimes you need one for a jam session or whatever, so when Robben Ford started using the Zendrive, I bought one. I like it so much I ordered a couple more. Best OD pedal I have ever used.
Bill
NedKelly
PostPosted: Sun Jun 18, 2006 11:49 am    Post subject: Reply with quote
I always go by the feedback i.e. Harmony Central.
If they don't have feedback on Harmony Central forget it.
Deadman
PostPosted: Wed Sep 27, 2006 3:46 am    Post subject: Reply with quote
DAPHON E200D. Made in China, metal casing, the same chip as the Ibanez TS-9. Sounds identical to the Ibanez TS-9.
?15 new on Ebay. Bargain of the century!
tudor
PostPosted: Mon Oct 16, 2006 4:10 pm    Post subject: Reply with quote
Radial ToneBone Classic / British
or
Damage Control Demonizer or Womanizer
Roger
Guitargoblin
PostPosted: Fri Oct 20, 2006 1:28 am    Post subject: Reply with quote
Boss OD-3 does it for me (and it even rhymes!)
Guitar Greed
Ozeshin
PostPosted: Sat Oct 21, 2006 2:54 am    Post subject: Reply with quote
I've got a 20 year old TS9 that I've retired in favour of a Zoom G2 and the amp modelling features...beats anything i've used hands down.
tudor
PostPosted: Mon Oct 23, 2006 2:38 pm    Post subject: Reply with quote
Ozeshin,,
you're right - the old or modded TS-9 normally give all what you want them to do ... and provide a superbe sound !!
Roger
BTW - I play mine with the Damage Control as a preamp - phantastic !
Guitargoblin
PostPosted: Thu Nov 02, 2006 8:13 am    Post subject: Reply with quote
I suppose it's not technically an overdrive, but the Maxon Distortion Master is pretty........diverting (through Marshall style amps anyway)
Guitar Greed
japanstrat
PostPosted: Tue Nov 07, 2006 9:00 pm    Post subject: Reply with quote
Yeah I agree with deadman.
I owned an original Ibanez TS-9 and the DAPHON E200D is so close I can't tell the difference.
Chum
PostPosted: Mon Jan 01, 2007 6:59 am    Post subject: Reply with quote
Hi Guys, and a Happy New Year!!!
I have the following overdrive pedals: a TS5 Iba?ez Soundtank Tubescreamer, a Russian Electro Harmonix Big Muff Pi, and a Nobels ODR-1 Overdrive. The sound of the TS5 is quite close to the reissue TS9 Tubescreamer, but its not very durable, as the casing is made of plastic. I'm thinking of having it rehoused in a metal casing.... The Big Muff is more like a fuzz, but it does the overdrive thing quite well too... The Nobels is the best sounding of these three, just my opinion anyway.... equal to the TS9 (i borrowed a buddy's TS9 to compare them; i used a Fender Princeton Tube amp).... I usually hook up the Big Muff and the Nobels, or sometimes a Jim Dunlop Fuzz Face to the Nobels..... I also usually add a dash of chorus (i use the Boss CE2), and that's my sound.... very warm, but i can go to scream mode using the bridge pickup of my Springy Sound.....
Well, that's my set up.... I recently got a Danelectro Fab series Overdrive (they are quite cheap!!!); very nice sounding, although flimsy as well due to its plastic casing.... Cheap though....
deadman and japanstrat, you mentioned the Daphon E200D.... I''m going to look for that one, thanks for the tip!!!
Cheers!!!
Chum
Page 2 of 4
