Toggle switch for LS150 2005
Tokai guitar discussion
CelestialSounds
Post by CelestialSounds » Fri Sep 13, 2019 10:38 am
Hi folks
was a member here many years ago under another username and now just re-registered.
I am the proud owner of 2 Tokais - 1 LS150 2005 Sunburst and a beautiful SG185.
I have an issue with the selector switch in the LS150 - which has become intermittent and "dodgy".
Can anyone recommend ( in the UK ) a good replacement ( Switchcraft etc ) ?
I believe I need to be careful of the size I get - a standard Paul switch might not fit ?
Cheers
Pete
Re: Toggle switch for LS150 2005
Post by villager » Fri Sep 13, 2019 11:39 am
try some contact cleaner first...
Post by brokentoes » Fri Sep 13, 2019 6:19 pm
I agree with trying the contact cleaner first, also lets see your 2005 LS150 !!! and SG185 !!!
aroomstudios
Post by aroomstudios » Fri Sep 13, 2019 8:14 pm
For modern Love Rocks Tokai I believe Tokai uses. This is what was in a custom ordered LG series (PRS type) guitar I just got from Tokai a month ago. The Love rock should use the exact same part. All my older Love Rocks have had all the electronics swapped so I cannot check those.
ALL PARTS
EP-0066-000 nickel
EP-0066-002 gold
EP-0066-003 black
It is a panasonic 3 way switch. The Panasonic switch is the same as the All Parts one. I forget the Panasonic part number. You can get this for $12.00 or so on Ebay and similar sites.
But yes, I would try to clean the 3 way switch first then order this is all else fails.
CelestialSounds
Post by CelestialSounds » Sat Sep 14, 2019 7:02 am
Thanks Guys - much appreciated,
I'll try switch cleaner again first, but I think the contacts have worn maybe too much.
I'll do some pics of both guitars when I get a chance.
Pete
Paladin2019
Post by Paladin2019 » Sat Sep 14, 2019 3:04 pm
That part will be a direct replacement but it will suffer the same fate eventually. Use part# SW-210-N and you'll never have problems again. It cost more but it's worth it.
aroomstudios
Post by aroomstudios » Wed Sep 18, 2019 8:56 pm
I have had much better luck with the Panasonic switches that with Switchcraft switches. For me they seem to last much longer and work better.
