Building a lefty tele
Goto page Previous  1, 2, 3
JuniorEnthousiast
PostPosted: Thu Mar 15, 2012 2:58 pm    Post subject: Reply with quote
Thanks guys.
va' sa' du? va' hete' du?
JuniorEnthousiast
PostPosted: Fri Mar 16, 2012 8:01 am    Post subject: Reply with quote
Little mock up. Everything's on there a bit crooked and I'll be cutting a new pickguard but this'll be the look of it. GSP TwangMaster (Dutch brand) in the bridge and HiLoTron in the neck;
Whatchu say?
JuniorEnthousiast
PostPosted: Sun Apr 08, 2012 11:44 am    Post subject: Reply with quote
This build hasn't been updated in a while, mostly because I've been busy making ???. With Easter's long weekend and all I thought I'd see if I could get in some trouble in the garage.
A new roundover bit (3,3mm or 1/8" radius) arrived by mail a week or so ago and I thought I'd give it a go. Went well on a scrap and fabulous on the body itself;
That is after some light sanding to take out the minimal amount of router seam.
Then I thought I'd address what was left visible and tangible of the breakouts that template routing had left;
Not sure if that was a wise decision to use CA glue to fill those tiny tearouts... We'll see if it was or wasn't tomorrow...
PostPosted: Mon Apr 30, 2012 11:40 am    Post subject: Reply with quote
Something is wrong with this Tele but I can't put my finger on it...
Hmmmm....
Mick51
PostPosted: Tue May 01, 2012 10:49 am    Post subject: Reply with quote
Hmmmm....
Negatives mounted upside down?
JuniorEnthousiast
PostPosted: Sun May 06, 2012 1:57 am    Post subject: Reply with quote
O, you guys. You slay me...
Haven't been able to do much (or any) work on the tele lately. Busy season has started. Evenings are spent dozing off, weekends spent catching up on sleep.
JuniorEnthousiast
PostPosted: Thu Aug 23, 2012 2:17 pm    Post subject: Reply with quote
Finally getting a bit of time to do some more work on this build;
JuniorEnthousiast
PostPosted: Fri Aug 24, 2012 4:21 am    Post subject: Reply with quote
Drilling for wiring;
I have to get my forstners from the bottom of a drawer before I can drill for the jack socket, it'll most likely be tomorrow before that happens.
JuniorEnthousiast
PostPosted: Mon Aug 27, 2012 9:25 am    Post subject: Reply with quote
For the electro socket I mark where the centre goes, drill with 3mm to be able to centre Forstner, then the 22mm Forstner (socket size) and last with 8mm bradpoint spiral for wiring. here's my tools for today;
Haven't got much to share today, so here's a bit of an icky pic;
Cav HB
PostPosted: Fri Mar 08, 2019 11:32 am    Post subject: Reply with quote
Why is there no "finished" pics?? After all that work, too...
Am I the only one who needs to see how this turned out?
Page 3 of 3
