What year? 1966 replica SS60
TheGoat
Post by TheGoat » Fri Feb 15, 2019 7:17 pm
Hi all. Picked up my first Tokais. An ‘84 Goldstar Sound ST50 candy red ‘56 type E pickups Kluson style tuners and this black beauty. I am blown away by the quality of these guitars. I have a light relic fender custom shop and this ‘66 is on par. The finish is light, don’t know if it’s poly or nitro, the grain is visable. I don’t see any seems in the body wood. Check out the wiring and tie wrap on the pickups. Any ideas on the year. Thanks.
Post by Peter Mac » Sat Feb 16, 2019 3:11 am
it would be 1982, March production.
TheGoat
Post by TheGoat » Sat Feb 16, 2019 7:16 am
Thanks. Is that from the cavity numbers? Also do you know what finish was on these models. Thanks. I have looked and I haven’t been able to find much info on this one.
Post by Peter Mac » Sun Feb 17, 2019 2:03 am
Hi 'Goat'
So the spec for this model was an Alder body with poly finish. It was essentially a SpringySound in terms of body, routing,
electronics, hardware and finish but had a one-off style neck - Springy with a large headstock and laminated fingerboard. Add to that the 1966-style Fender serial number (6 digits) and I hope you are getting the picture.
It had a run of only 4 years making it the rarest of SilverStar models.
I have only ever seen them in 3 colours - Black, Olympic White and 3T Sunburst.
regards
Hodge69
Post by Hodge69 » Sun Feb 17, 2019 12:22 pm
I'd have said 1981.
Who put the bop in the bopshuwopshuwop?
7okai did.
Post by Peter Mac » Sun Feb 17, 2019 3:52 pm
. . .and you would have been wrong, Hodge.
1981 SS-60 would be a 1976 replica with bullet truss rod, 3 bolt neck and a 7 digit serial# on the headstock.
1982 was when Tokai went to Fender style serial # for the respective Years, hence a 6 digit number for 1966 - 1974 replicas.
As the sequence started at 100000, this one is the 637 guitar made from the '66-'74 era . . (this sequence was also used on TE, PB and JB models) so it is not the 637th SS-60 from 1982. . . but would have been a very early one none-the-less being a March production.
TheGoat
Post by TheGoat » Sun Feb 17, 2019 4:04 pm
Thanks for the info. You mentioned 3rs production of the SS60 model. With an ‘81 being a 3 bolt design, was there an ‘83 4 bolt SS60 or an ‘80 3 bolt SS60. In other words is the 4 bolt SS60 a 1 year only?
Post by Peter Mac » Sun Feb 17, 2019 4:27 pm
Hi Goat,
No, the 4-bolt SS-60 was made through to 1985 when it ceased production. 1982 was the only Year the SS-60 4-bolt had the spaghetti logo. Later Years have the script logo.
That's what makes it so rare.
Peter mac
TheGoat
Post by TheGoat » Sun Feb 17, 2019 4:50 pm
Thanks for sharing your knowledge on the subject.
I can’t believe I waited so long to pick one up. Great guitars!!
