1986 Tokai ST60 Goldstar sound strat Bridge dimensions
yahonza
PostPosted: Sun Aug 05, 2018 7:52 pm    Post subject: 1986 Tokai ST60 Goldstar sound strat Bridge dimensions Reply with quote
I've had a 1986 Tokai ST 60 Goldstar sound strat from new, however I changed the bridge a couple of times over the years (original disappeared sadly). Am looking to get it back into original shape, but can't seem to find accurate info on the correct bridge size, string spacing etc. Any info welcome.
The string spacing on the Gotoh Traditional Tremolo for Strat is too large (56.13mm), seems the originals should be around 52mm.
bluejeannot
PostPosted: Thu Aug 09, 2018 4:16 pm    Post subject: Reply with quote
https://www.guitarfetish.com/Wilkinson-Vintage-Tremolo-Pop-In-Arm-with-Block_p_897.html I have fitted these to a couple of Goldstars.Great bridge with a proper steel block.Fits like glove;
bluejeannot
yahonza
PostPosted: Mon Aug 13, 2018 1:24 am    Post subject: Reply with quote
Thanks, have seen this but wasn't sure of the string spacing, though does seem to be less than 56mm from the drawing
