Sonix by Deviser LP Sp. (Momose)
guitar hiro
PostPosted: Mon Apr 30, 2018 6:52 pm    Post subject: Sonix by Deviser LP Sp. (Momose) Reply with quote
going back to the early/mid 2000s (some) Sonix branded guitars have been made by Deviser, parent company to Bacchus, Headway, Momose, etc.
Recently located a Sonix marqueed Les Paul Sp. with the 'Custom Craft Guitar' head stock logo = same logo as the original run of Momose MLS-STD/J.
This one is in the 01** serial number range = same four digit serial number scheme as Momose.
So, actually this (Sonix) Les Paul Sp. is a re-branded Momose & this one is likely from about 2002/2003.
Looks like a 1 piece body with a reported weight of 7 lb. - 1 oz.
Can't go wrong with Deviser, Bacchus, Momose so, finally getting a Sonix fiddle & glad to be getting one from the 'original' run of Momose production.
Soon will no longer be a Sonix virgin and will be great company for my Momose MLS-STD/J, number 08**
PostPosted: Mon May 07, 2018 7:19 am    Post subject: Reply with quote
Pictures?
guitar hiro
PostPosted: Sun May 13, 2018 11:24 am    Post subject: Reply with quote
hey marcus, I don't have a photo host; used to do photophucket but we all know how that one ended up
wulfman
PostPosted: Sun May 13, 2018 2:59 pm    Post subject: Reply with quote
It looks a bit like mine...
PostPosted: Sun May 13, 2018 5:53 pm    Post subject: Reply with quote
Wow. That's nice, Harold!
guitar hiro
PostPosted: Mon May 14, 2018 4:57 am    Post subject: Reply with quote
yes, the head stock face on the LP Sp. looks just like the one on Harold's SG with the Custom Craft Guitar log & the Sonix marquee
That is one sweet SG Harold Does it have the four digit serial # scheme like the original Momose examples?
wulfman
PostPosted: Wed May 16, 2018 4:07 pm    Post subject: Reply with quote
Yes, it does have the same S/N format. Mine is a "Regular Sonix" line and not the "Hi Spec Line"
Check it out through the Wayback Machine:https://web.archive.org/web/20070208174729if_/http://www.sonicsystem.co.jp:80/webguitar/SONIXmain.html
guitar hiro
PostPosted: Thu May 17, 2018 5:42 am    Post subject: Reply with quote
thanks for posting the links Harold those Sonix are some nice looking axes
if you look at the Sonix Regular Line link, third guitar from the bottom, the LP-SPL VS, that looks exactly like the guitar I purchased.
It most likely is the very guitar I bought.
part of the verbiage, translated of course:
Thin lacquer painting !! Non-buffed finish
This time LPSPL is only production of 2 pieces
production of 2 would seem to make this one fairly rare
guitar hiro
PostPosted: Fri Jul 06, 2018 5:18 pm    Post subject: Reply with quote
Sonix Custom Craft Guitar Les Paul Special arrived today will add some comments in a few days after I put it through some evaluations.
Actually showed up with the original factory warranty card which I had no idea that was included
guitar hiro
PostPosted: Sat Jul 07, 2018 10:37 am    Post subject: Reply with quote
so, some quick observations about the Sonix LP Special
Model. LPS-56 A.F MAHO/ROSE/LQ
Color. VS
The above is exactly as printed on the original Sonix warranty card.
This example looks to be all original as there are no indications of any changes.
Weighs in at just a hair under 7 lb. - 4 oz., chunky neck thickness/not thin & not baseball bat, aluminum stop tail, acoustically VERY lively & SUPER resonant.
I have owned a very good representation of Deviser produced solid body guitars & basses.
These are typically either 1 piece body construction, or 2 piece/center seam body construction.
The 2 piece/center seam examples are typically very easy to identify because of either (1) the finish color allows for visual ID, or (2) the center seam typically leaves a very minute indication of the seam in the finish. I had no idea if this example would be a 1 piece body, or a 2 piece, as the seller had no idea.
I have tried to no end to locate any indication of a center seam on this example and have found nothing.
Because of this I am currently assuming this example has a 1 piece body. Further investigation is in order to prove/disprove this.
The finish on this guitar is SUPER thin; it's almost not there it's so thin.
It is what Deviser calls a NBF aka 'non buffing finish' which is a super thin lacquer that is of course, not buffed to a gloss after drying.
The top color is a dark burst/tobacco burst, and the sides & back are a very unusual very dark cherry. To see any grain thru the very dark cherry finish you have to take the guitar into the sun light, or use a flash light.
Construction, fit & finish, fret work, everything on this guitar is top shelf quality one would expect from a Deviser produced instrument.
This Sonix is a great chunk of Mahogany & could be the one LP Special that I actually end up keeping; time will tell.
wulfman
PostPosted: Sat Jul 07, 2018 2:15 pm    Post subject: Reply with quote
Hey Hiro,
How about a picture or two?
Cheers,
Wulfman
guitar hiro
PostPosted: Sat Jul 07, 2018 3:22 pm    Post subject: Reply with quote
wulfman wrote:
Hey Hiro,
Cheers,
Wulfman
yo Harold, what if I email you some pics (from the Sonix's listing) and you post them? I don't have a photo host. I know; I suck
wulfman
PostPosted: Sun Jul 08, 2018 9:05 am    Post subject: Reply with quote
Works for me, send them over.
guitar hiro
PostPosted: Sun Jul 08, 2018 12:00 pm    Post subject: Reply with quote
Harold, 'you have mail'
Thanks
wulfman
PostPosted: Sun Jul 08, 2018 8:10 pm    Post subject: Reply with quote
Nice looking axe:
