Tokai made Greco SA ES 335 Model
Tokai guitar discussion
CliffsComicWorld
Post by CliffsComicWorld » Sat Apr 21, 2018 11:59 am
Aloha Crew,
Been wondering what model this guitar is and think I know now. i understand that Tokai made some Grecos in the 1980’s but I did not know they made some SA Models. Here is the run down.
No label or serial number
Stripped Ebony fretboard
Fret end bindings
Square routes for the pickups
Off center center block
Flamed maple top
Birdseye back
Gold bottom unmarked pickups
Anyone else?
https://www.flickr.com/photos/147832065 ... 7453940008
ImageUntitled by Cliff Jordan, on Flickr
Last edited by CliffsComicWorld on Sun Apr 22, 2018 12:42 am, edited 4 times in total.
Paladin2019
Re: Tokai made Greco SA ES 335 Model
Post by Paladin2019 » Sat Apr 21, 2018 1:01 pm
CliffsComicWorld wrote:Aloha Crew,
Where did you hear this?
CliffsComicWorld
Post by CliffsComicWorld » Sat Apr 21, 2018 6:56 pm
It’s known that Tokai made Les Paul type guitars for Greco in the 1980’s. The hints are offset neck tenons and square routing for the pickup up feet in the body’s. These are Tokai construction traits.
Here is the pickup cavity routes on the Greco SA Model
Last edited by CliffsComicWorld on Sun Apr 22, 2018 12:47 am, edited 2 times in total.
Post by villager » Sat Apr 21, 2018 11:31 pm
well documented i have a few of them.. even have the tokai stamping in the cavitys sometimes..
CliffsComicWorld
Post by CliffsComicWorld » Sun Apr 22, 2018 12:18 am
The pickups are a mystery.... will have to break out my meter and measure them... they actually sound pretty good. I think I’ll pull a pot and see if there is a date on them.
Post by villager » Sun Apr 22, 2018 12:53 am
dont think the pu are original cliff, all the tokai made used the braided wire greco pus of the day...
_JDZ
Post by _JDZ » Sun Apr 22, 2018 8:18 am
First post for me here...
I have one just like Cliff's.
Pickups are the same:
Image3 by JDZ, on Flickr
Cavity routing is the same as on my 81 Tokai ES-150. Fujigen made Greco's don't have the relief in bridge PU cavity either, just a hole for the wire:
ImageBridgeCavity_s by JDZ, on Flickr
ImageBridgeCavity by JDZ, on Flickr
ImageDSC01534 by JDZ, on Flickr
ImageDSC01532 by JDZ, on Flickr
ImageDSC01517 by JDZ, on Flickr
ImageDSC01511 by JDZ, on Flickr
ImageDSC01498 by JDZ, on Flickr
John
_JDZ
Post by _JDZ » Sun Apr 22, 2018 8:47 am
Here's one of the POTs from mine
Given the open O on Greco (Mint Collection) and that Tokai was making Greco's in late 80's/early 90's, the pot would be FEB 1991?
Image20180323_221306 by JDZ, on Flickr
Post by villager » Sun Apr 22, 2018 1:15 pm
interesting.. wonder why they used those pu and not the greco ones...
_JDZ
Post by _JDZ » Sun Apr 22, 2018 1:56 pm
Do you know what kind of pickups they are?
wulfman
Post by wulfman » Tue Apr 24, 2018 4:29 am
I don't think you can be sure the pots are also original if it had a pickup change. Beautiful guitar regardless of the year.
_JDZ
Post by _JDZ » Tue Apr 24, 2018 5:20 am
Thanks!
Both Cliff's and mine have the same pickups.
Assumed they were original to the guitars since they look to be the same?
Post by villager » Tue Apr 24, 2018 8:38 am
_JDZ wrote:Do you know what kind of pickups they are?
no I have never seen those type before..
duff
Post by duff » Tue Apr 24, 2018 3:14 pm
build by tokai, painted by greco?
CliffsComicWorld
Post by CliffsComicWorld » Wed Apr 25, 2018 11:24 pm
I’ll pull a pot and take a picture of the pot codes....both of our guitars have this in common.
Tokai built
Gold bottom pickups
Neck pickup has black wire lead
Bridge pickup has Gray wire lead
To be continued.....
