Ok. It looks like it *could* be a 200, but there are a couple of issues. First, it's has some mods. I think the selector switch is new, as are the tuners, truss rod cover, and if it's a 200 then the scratchplate has been fitted aftermarket as well. This sort of thing always muddies the waters.
Second, 200's are supposed to have ebony fretboards. Yours is only a couple of serial numbers away from mine, and mine is jet black whereas yours could be very light ebony or dark rosewood.
It's hard to make out the flame pattern, or see how many pieces the back is made from.
You're going to need to take the covers off the back and take photos of the switch and electronics. If you want to be sure then you will also need to take the pickups off and photograph their undersides and the cavities. Get good shots of all sides of the pickup cavities. The most reliable way to tell if this is really a 200 will be if the top is solid, so we need to see if the centre joint and grain lines match up.
