Tokai Strat ?????
funkilius
Ireland
Expert opinions appreciated on this one please... :eek: :eek: :eek: :eek: :eek:
http://www.ebay.ie/itm/131527979497?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
thanks in advance........
St 40 based Bitsocaster,with ceramic pickups and what looks like original neck plate.The neck should should have lam board not slab like this one which means it is not original and the saddles should be pressed steel not solid mazac.Vastly overpriced.Avoid.Gabe
thanks for info
certainly overpriced............ 8) 8) 8)
as a matter of interest....................how to tell difference between lam and slab board ????
if you look at the amount of wood showing on the fretboard to headstock side behind the nut .on a lam board there is very little and it generaly curves.
whereas on a slab board it is straighter and wider
