Lucke Luke
A while ago I bought some hercules wall hangers and I've been meaning to install them.
I've got a dry wall and although I could seek out the studs behind it, the spacing that I wish to have for the guitars would probably not work.
Those that have done something similar, what kind of wall plugs did you use as they range from little plastic ones, to slightly more substantial metal ones?
All the guitars I have don't weigh more than 4.5kg I think... (LP,SG,ES335 & EX)
It's a rather small living room and there's only one meter wide space that I can utilize. Which probably means hanging two guitar side by side, and another one a bit lower, with the neck located between the other two... although ideally it'd be good to fit 4 hangers (probably impossible). I can figure the exact positioning later, unless you reckon there is any risk of having too much weight (16kg in total?) spread over a square meter of dry-wall.
Fire your advice!
L
Fire your advice!
L
