Direct swap for a 1986 Goldstar Sound AST40 tremolo?
Warmachine
I've already upgraded this guitars electronics and tuners and am quite happy so far. I'd like to find a quality trem unit that I could swap in. Is there a higher quality Fender or aftermarket unit that would pop in without much modification?
I don't know about Fender, but Gotoh, Schaller etc. normally have routing templates for their tremolos on their website, so if you don't mind doing a ton of measuring with any luck you might be able to find one which is a direct swap...
I figured I'd do some searching on google for Fender 62 reissues where people swapped out their bridges, not that I expect Tokai specs to be spot on with Fender...but probably in same ballpark I'd guess.
Fender Highway 1 bridges fit the vintage style mounting holes, but string spacing is slightly narrower. If the mounting holes line up on my Tokai I think the narrower string spacing might work to my advantage since I always have trouble fretting the low E string. I'm going to investigate this further and maybe give it a shot. Would be an inexpensive upgrade.
Highway 1 Strat (2006 and later)
6-pivot bridge
2 1/16 string spacing.
2 7/32 mounting spacing
Wilkinson tremolos with solid steel block are very good and cheap
WVC SB and WV6 SB should fit
