How Heavy is Heavy?
Goto page Previous  1, 2
petercrisscuola
PostPosted: Wed Apr 16, 2014 9:26 am    Post subject: Reply with quote
Call me stupid if you like, but I love the sound of that damn guitar.
PostPosted: Wed Apr 16, 2014 10:52 am    Post subject: Reply with quote
Nothing stupid about it at all.... don't worry about the weight if you play it sitting down. If it sounds and plays good, then have at it. You're not going to dump your best girl if she gains a few pounds - just more to love.
Some people say that the heavier Les Pauls sound better
8bit Barry
PostPosted: Wed Apr 16, 2014 5:53 pm    Post subject: Reply with quote
Peter Mac wrote:
In 36 years, I have owned 16 Les Pauls and worked on many more and find that around the 4.0 kg mark seem to work for most players.
There's the good answer - thanks Peter
8bit Barry
PostPosted: Wed Apr 16, 2014 5:57 pm    Post subject: Reply with quote
jacco wrote:
Well, the weight to uphold stays the same, no matter the strap length.
What does matter is;
1. the angle the strap makes on your shoulder for this changes the the amount of body contact surface
2. the width of the strap for this changes the amount of body contact surface
3. the position of the strap on your shoulder
4. the shape of your body
5. the physical condition of your muscles
The main muscle that need to uphold guitar through the strap is the trapezius.
The function of this muscle is to lift your shoulder and to position/stabilize your shoulder blade (it's predominantly a posture muscle).
This muscle is quite large and has several sections. The upper section goes from head & upper vertebrae to top side of the shoulder blade & clavicle.
This part is where the strap rests on also.
The further the strap is positioned towards the shoulder the more work this muscle has to do. So it would be better to have the strap rest more towards the neck.
The problem is that there are many variations in trapezius angle in humans. If you have a sharper angled trapezius (which also enhances when you do fitness work out) the strap will automatically slide more towards the shoulder.
When you make your strap too short you will have to lift your arm sideways a bit to reach the upper frets, which in turn will activate the trapezius. So a high position will fatigue the trapezius earlier.
When you make the strap too long, you get the feeling it will slide off of your shoulder, so that activates the trapezius too (and will cause overuse of your wrist because of the increased angle).
Training of the trapezius, like dumbell flys and shoulder press will help you to have less fatigue when playing standing up.
What an informative reply. Thank you.
At last a reason to do exercise!
Thomas/Sweden
PostPosted: Thu Apr 17, 2014 8:48 am    Post subject: Reply with quote
I like the 4 - 4,3 Kg's for LP's. The OBG 57B however, is only 3,4 Kg but it still sounds great.
Barks67
PostPosted: Thu Apr 17, 2014 9:41 am    Post subject: Reply with quote
4kg and 4.2kg on my two. Those 200 grams make quite a difference if I use the same strap. Oddly still not as heavy as my old telecaster!
8bit Barry
PostPosted: Sun Apr 20, 2014 3:01 am    Post subject: Reply with quote
Thanks for the medical info Doc - I never knew any of that...
Page 2 of 2
