Guitar case rack
Antwerp, Belgium
Guitar cases are taking up too much space, so I decided to make a case rack.
My first attempt:
Mind you, I?m not a carpenter, nor do I have any wood making machines.
nice one......could do with one of these.........
can you post the dimensions of wood used?
Nice job, how many cases you figure it can hold ?? 3 like the one that's in there for reference ?
Felix, great work.
I would suggest putting on the bottom and sides any kind of soft cloth or the like. I just put a so-called here "fieltro"
http://www.google.es/imgres?imgurl=https://ecom.amenworld.com/WebRoot/ce_es/Shops/210677/MediaGallery/IMG_3133.JPG&imgrefurl=http://www.o-karamba.es/&h=2112&w=2816&sz=657&tbnid=xscsf0SUtCwbAM:&tbnh=93&tbnw=124&prev=/search%3Fq%3Dfieltro%26tbm%3Disch%26tbo%3Du&zoom=1&q=fieltro&usg=__2LPxr-xdwiEecSmsEHYbg-q1Mpg=&docid=yMctPoOklGPzPM&sa=X&ei=-zKfUeKNA-fB7AaG0ICYDA&sqi=2&ved=0CD4Q9QEwAA&dur=266
It has some adhesive on the back so it is easy to fit.So the cases will not be ragged or scratched.
