Author |
Message |
mateo69 Plucker
Posted: Thu Oct 18, 2012 5:17 pm Post subject: Help identifying Fernandes strat |
Hey everyone, I just picked up what is labeled as a MIJ Fernandes Strat...but I have a few questions about it.
The heel of the neck is stamped LE-1,97
Can I assume this is a LE-1 from 1997?
The body was sanded down and sealed...the original color appears to have been seafoam green.
When I did an internet search for "LE-1 green" I find a LE-1Z in seafoam green but it has a Rosewood fingerboard, not Maple like this one.
There is a stamp in the neck pocket which is slightly smudged and looks like "ST-36"...but I also think there is the top of a "5" maybe right after...so "ST-365"...does that mean anything? Color code possibly?
Here's a pic of the electronics if that helps identify if it is original as well. It's an 8-hole, single ply white pickguard with a YM-50 5-way switch and small pots.
I just want to figure out if this is the original Fernandes body for this neck.
Any help is appreciated! |
Back to top |
bluesyrat Guitar God
Joined: 17 Feb 2012 Posts: 395 Location: Latina, Italy
Posted: Fri Oct 19, 2012 11:23 am Post subject: |
could you post headstock and tuners pics? _________________ fusion music make me puke |
Back to top |
mateo69 Plucker
Posted: Fri Oct 19, 2012 12:50 pm Post subject: |
Here is the front of the headstock -
...and the back of it -
Back to top |
jacco Guitar God
Joined: 25 Feb 2010 Posts: 2871 Location: Netherlands
Posted: Fri Oct 19, 2012 1:15 pm Post subject: |
Looks like a post 2000 model, do you have a close up of the pots? |
Back to top |
mateo69 Plucker
Posted: Fri Oct 19, 2012 1:41 pm Post subject: |
Here are the pots...I don't recognize the logo on them...and Yes...someone unsoldered the ground lead on the volume pot -
Back to top |
Posted: Fri Oct 19, 2012 1:45 pm Post subject: |
Could be a Limited Edition of late '90's (or early 2000); it seems, basing on headstock shape, gotoh tuners and sticker serial number. It has been renamed retrorocket after early 2000's i think.
The stamp on the neck pocket make me think to a a slightly earlier (mid '90's) model. Anyway the guitar is legit and there is a very high probability that neck an body are correctly matched.
Fernandes often shows up strange models on strats...
Probably Jacco could help better... especially if you post pots pics...  _________________ fusion music make me puke |
Back to top |
mateo69 Plucker
Posted: Fri Oct 19, 2012 1:55 pm Post subject: |
Thanks bluesyrat!
I've seen the 'retrorocket' but they seem to have a modified strat body and this one appears to be an exact strat copy like the 'limited edition' models. |
Back to top |
Posted: Sat Oct 20, 2012 2:41 am Post subject: |
Yep. I should have said transformed ... _________________ fusion music make me puke |
Back to top |
