Orville Std?
jericojuliolab
PostPosted: Fri May 13, 2011 11:33 am    Post subject: Orville Std? Reply with quote
Hi Guys.
Bought this few months ago. I know its 1994 Fuji-gen made Orville.
But I do not know the exact model whether it is a standard or a 58 copy.
Any help wil be appreciated.
Thanks
http://s56.photobucket.com/albums/g180/jericojuliolab/orville/
My: LP Burny FLG-120/Orville 58 copy
PostPosted: Sat May 14, 2011 5:06 am    Post subject: Reply with quote
off topic: any chance to see some pics of your Burny?
jericojuliolab
PostPosted: Sat May 14, 2011 6:16 am    Post subject: Reply with quote
Above link is for the Orville
Here's a link to my Burny
http://s56.photobucket.com/albums/g180/jericojuliolab/burny%20FLG-120/
Thanks Jacco
soundcreation
PostPosted: Sun May 15, 2011 2:17 am    Post subject: Reply with quote
I've never heard of a non "by Gibson" orville refereed to as anything other than just an Orville.
It's not a reissue if that's what you're thinking.
jericojuliolab
PostPosted: Sun May 15, 2011 6:34 pm    Post subject: Reply with quote
Thanks Soundcreation>
Reason for me posting this here is my ignorance. Not much knowledgeble on Orville models.
Really appreciate it.
I was just thinking it may be a model other than a standard Orville
soundcreation
PostPosted: Mon May 16, 2011 7:25 am    Post subject: Reply with quote
no problem.
A general guide is...orvilles are just orvilles.
Orville 'by gibson' (as written on the headstock) models: The standards say "standard" on the truss rod cover. The reissues are like yours and don't say anything on the truss rod cover. And they have fret edge nibs.
jericojuliolab
PostPosted: Mon May 16, 2011 7:45 am    Post subject: Reply with quote
Thanks.
Again another learning I got.
GammyBird
PostPosted: Mon Jun 13, 2011 7:58 pm    Post subject: Reply with quote
There was no 58 Orville/ObG LP reissues. There was a 57 and a 59.
Couple of things to look for when you suspect you've found one
1. Fret edge binding
2. Black cavity covers
3. Gibson pups
4. No heal cap
5. Sometimes there will be a space after the first number, in the serial number. For example Fujigen will be 3 9999 and the Terada will be G3 8888. This being said, I've seen lots of reissues with no space in the serial number.
59R will have a veneer on maple top, 57C is a plain top and the 57B is the Custom reissue.
EDIT: There is also a 54 reissue that has P90's.
jericojuliolab
PostPosted: Tue Jun 14, 2011 6:27 am    Post subject: Reply with quote
Thanks for that additional info Gammybird.
I suppose the 54 reissue with p90 for an Orville that you mention here is a Goldtop.
GammyBird
PostPosted: Tue Jun 14, 2011 7:01 am    Post subject: Reply with quote
Seen those too have you? Yes gold and I've also seen them in black, they tend to be expensive.
jericojuliolab
PostPosted: Tue Jun 14, 2011 11:50 pm    Post subject: Reply with quote
Hi Gammybird,
Actually am expecting an Orville LP said to be arriving by early July.
Don't know the total specs yet but said to be:
1. A gold top with humbucker ( pup not known yet )
2. Made at Fujigen plant
3. a 57 reissue with five digit SN starting at 7
4. made in year 94 or 97
Will know the total specs once it arrives.
What other things I may have to look at on a Orville 57 reissue goldtop?
Many thanks for your unselfish advices.
Rgds
PostPosted: Wed Jun 15, 2011 12:13 am    Post subject: Reply with quote
If it starts with a 7 it's a 1997 model. I don't think 1997 models are reissues. Those will have gotoh pups.
PostPosted: Wed Jun 15, 2011 1:55 am    Post subject: Reply with quote
I have had ObG's 54-models in gold and black which were non-reissues.
GammyBird
PostPosted: Wed Jun 15, 2011 5:08 am    Post subject: Reply with quote
This is what is listed in the 92 Catalogue....Neither are listed as a reissue, but then again there isn't a 59R model in the catalogue either and we know they exist. There isn't a P90 model listed in either catalogue for 93, 94 or 96. I have seen Orville P90's before but does anybody know which year they were released?
Joop
PostPosted: Fri Jun 17, 2011 9:30 am    Post subject: Orville STD Reply with quote
3. Gibson pups
4. No heal cap
Sorry Gammybird but I think that not all of your points are correct in my humble opinion.
For example white cavity covers still could be a '59R but it will be a Terrada made one instead of Fujigen (who always used black), and the same goes for point 4 which also would point to a Terrada made guitar regardless of the model (they used the heel on many of their models).
What you describe apart from the fret edge binding(which should be on all 59R's) is a ObG Fujigen made '59R and not by all means any ObG 59R.
Ok?
regards,
Joop
