Author |
Message |
jacco Guitar God
Joined: 25 Feb 2010 Posts: 2871 Location: Netherlands
Posted: Wed Mar 23, 2011 3:35 pm Post subject: |
No, more likely a Cort (Korea) made Greco |
Back to top |
LessPoul Plucker
Posted: Wed Mar 23, 2011 3:43 pm Post subject: |
Thank you. Think I will skip the one I have been offered then. It is claimed to be a Tokai made - but no serial what so ever to spot on the guitar. |
Back to top |
jacco Guitar God
Posted: Wed Mar 23, 2011 4:01 pm Post subject: |
Tokai made Greco's don't have a serial only a model type in the pickup cavity. Sometimes it also lacks the model type so it's good to know how to identify a Tokai opposed to Cort:
Tokai: square tab routing, Cort: oval tab routing
Tokai: medium tenon, Cort: long square tenon (often with bolt)
Tokai: diagonal wire routing, Cort: straight wire routing |
Back to top |
Koubayashi Guitar God
Posted: Wed Mar 23, 2011 4:58 pm Post subject: |
jacco wrote: | Tokai made Greco's don't have a serial only a model type in the pickup cavity. Sometimes it also lacks the model type so it's good to know how to identify a Tokai opposed to Cort:
Cort made Grecos also have a different kind of plastic in the inlays, the logo and the diamond in case its a Custom. Further, you can see it on the screws which holds the bridge. Also, the Japanese often have nickel and the Korean regular chrome. All of which can be identified easily if the seller provide decent pictures. |
Back to top |
jacco Guitar God
Posted: Thu Mar 24, 2011 12:09 am Post subject: |
Yeah I was talking about easy to identify diffs in the cavities.
We're forgetting the block nut and coloured pup wire on Corts. |
Back to top |
LessPoul Plucker
Posted: Thu Mar 24, 2011 1:29 am Post subject: |
He he, this is really tricky territory for a newbie...
Could anyone post a picture or two, of the differences between the Cort and Tokai made Greco LP Custom?
Here is a picture of how it looks. It has the same wire and tenon - but not the "egc 75" stamp.
http://i456.photobucket.com/albums/qq282/clines99/tok/212d-3.jpg |
Back to top |
japanstrat Guitar God
Posted: Thu Mar 24, 2011 4:58 am Post subject: |
That's a Tokai made Greco.
Note the 2 square shaped shallow holes on each side of the bottom of the pickup cavity, that's done by a Tokai factory router.
 _________________ When I was a kid my parents moved a lot, but I always found them. Rodney Dangerfield |
Back to top |
jacco Guitar God
Posted: Thu Mar 24, 2011 5:37 am Post subject: |
Differences between Tokai & Cort made Greco's from this picture:
1. Tokai: square tab routing, Cort: oval tab routing
2. Tokai: diagonal wire routing, Cort: straight wire routing
3. Tokai: medium tenon, Cort: long tenon
4. Tokai: braided pup wire, Cort: coloured plastic pup wire
5. Tokai: fret edge binding, Cort: no fret edge binding
Tokai:
Cort:
Back to top |
Posted: Thu Mar 24, 2011 7:14 am Post subject: |
Many Tokai made Greco do not have FEB.
But if one has then there is no doubt. |
Back to top |
dombat Guitar God
Posted: Thu Mar 24, 2011 9:19 am Post subject: |
6. Tokai: no paint onto the pickup routings, Cort: mat black isolation paint
7. Tokai: regular diameter pots, Cort: small diameter pots
8. Tokai: not centered tenon, Cort: centered tenon |
Back to top |
LessPoul Plucker
Posted: Thu Mar 24, 2011 10:12 am Post subject: |
Thank you very much for this info. |
Back to top |
muccax Guitar God
Posted: Thu Mar 24, 2011 1:04 pm Post subject: |
hi
some time ago i had a cort made greco .... and it had the normal size pots
all the best
otto |
Back to top |
Ratae Corieltauvorum Power chords are my friend
Back to top |
Posted: Tue Apr 05, 2011 2:43 am Post subject: |
Yes, that's a Tokai made Greco EGC-75. _________________ When I was a kid my parents moved a lot, but I always found them. Rodney Dangerfield |
Back to top |
dryuch I only know 3 chords
Posted: Fri Dec 01, 2017 8:37 am Post subject: |
Hi! One qwestion: what model of pickups used in Tokai made Greco eg-75? |
Back to top |
