Hassouni said:
I mean, I don't really care if the pickup rings don't look right and the archaic celluloid was used on the inlays, as long as it sounds and sustains like a proper old LP
Hi Hassouni!
Don't take this personal, as it is not intended to be, but: how many old Les Pauls did you play in your life?
There is absolutely NO such thing as specific way of sound or sustain that all of these guitars inherit. EVERY guitar is different! There is also not one typical neck profile for 58, 59 or 60. The same goes for nearly every detail, there is a lot of variation.
A lot of people say, they want a Les Paul to sound like an old one, but the minority of them has ever played one. What they are after is something, they can't specify, because it's something that has been made up in their heads as an ideal sound of an (old) Les Paul.
I mean, I never played a real Burst over an amp, though I heard a few played thru amps, when I was in the room, and really, for me it sounded nothing the way, I thought it would sound. I don't mean it sounded bad, no, it didn't, it sounded great, but it wasn't THAT much of a difference.
If you are after resonance, pure resonance when played unplugged, then buy a hollowbody guitar, or a semi hollow guitar, or maybe a chambered historic. They all tend to resonate more in most cases, than solidbodies.
For me, a lot of the thing, that creates the sound of an old Les Paul is not so much the wood (I know, we could debate that 'til we die with no conclusion..), because that is something that can be recreated today. It's the pickups for me. I mean, basically, everything about those old Les Pauls is replicable, you can have the same wood, same lacquer, same glue, etc.pp., but it seems to be difficult to replicate the PAF, or a PAF from a certain period (again, a lot of variation) as far as I know.
If I were in the market for an absolute authentic sounding Les Paul, I'd go the way of letting me build one, or buy an old butchered Goldtop and convert it. That wpuld include original electronics from the 50's incl. PAFs -> it's going to be expensive.
You can also use a Historic or a hi end Tokai as a basis to go from there, but in either way, you would have to put more money in it on parts.
I think, the easiest way would be to define, what kind of sound you are really after. And if you have the chance, play an old Burst or listen to it as close as you can to get a thought about how a Burst CAN sound (as mentioned, they all sound different). And then you'll have to decide whether the sound of the Burst is really what you want, or not (which is absolutely possible).
Kind regards
Jonas
