How to install a second input for a cabinet
Goto page Previous  1, 2
t.olsen
PostPosted: Thu May 20, 2010 10:22 am    Post subject: Reply with quote
No,mono
t.olsen
PostPosted: Thu May 20, 2010 10:58 pm    Post subject: Reply with quote
Problem is solved ! I woke up this morning at 6.30 and had the right idea :
It is visible that 2 contacts of the socket are connected with a piece of wire.The result is a short circuit between + and - if there is nothing plugged in.I installed a second socket with the same bridge but when I used my internal speaker,there was no cable plugged in from the cabinet and the result was a short circuit between black and white wire on the foto.All I had to do was remove the wire between the socket contacts and that's it
PostPosted: Fri May 21, 2010 2:54 am    Post subject: Reply with quote
t.olsen wrote:
Problem is solved ! .......
Great news! You can sleep easily now
t.olsen
PostPosted: Fri May 21, 2010 2:59 am    Post subject: Reply with quote
Yes,it was too easy to find out...that shows that the best is always take a look first at the layout to make clear how parts work together and what is the sense behind it.It 's fine now
t.olsen
PostPosted: Fri May 21, 2010 3:09 am    Post subject: Reply with quote
But this was only one reason for sleepless nights...this is the main reason :
Needs more oil than gasoline...
PostPosted: Fri May 21, 2010 3:17 am    Post subject: Reply with quote
Very cool, but no-where for a 4x12 cab
PostPosted: Fri May 21, 2010 4:17 am    Post subject: Reply with quote
But they are the best lawnmowers in the world.
t.olsen
PostPosted: Fri May 21, 2010 4:30 am    Post subject: Reply with quote
Especially with 130hp..
Page 2 of 2
