what is the neck radius of goldstars?
beastman1
PostPosted: Tue Apr 27, 2010 1:52 am    Post subject: what is the neck radius of goldstars? Reply with quote
looking to put a simulated bone nut in 85 goldstar
what is the original goldstar nut made of? plastic?
blake375
PostPosted: Tue Apr 27, 2010 8:16 am    Post subject: Reply with quote
AFAIK, the radius is 7.5 and the nut is plastic. Knowing Tokai, this may not be consistent over the years.
beastman1
PostPosted: Tue Apr 27, 2010 11:06 am    Post subject: Reply with quote
k thanks
storm
PostPosted: Thu Apr 29, 2010 4:06 pm    Post subject: Reply with quote
beastman1 wrote:
k thanks
Hi when I refretted mine I checked radius with radius gauge and it was standard 7 and a quarter
As for the nut when you are buying them you only get 2 choices flat bottom or curved. Also don't forget the nut width and spacing. Theres usually 2 types of strat types import and american.
Regards
Storm
beastman1
PostPosted: Thu Apr 29, 2010 8:58 pm    Post subject: Reply with quote
what is the standard on there stock? flat bottom? or curved?
does any company sell a direct replacement that is also slotted? plastic? bone? whateva?
blake375
PostPosted: Fri Apr 30, 2010 2:18 am    Post subject: Reply with quote
Yes, 7.25 is right I think. I was wrong when I said 7.5.
PostPosted: Fri Apr 30, 2010 2:45 am    Post subject: Reply with quote
Most people say 7.5", but 7.25" is correct for vintage Fenders (theoretically) and their copies.
beastman1
PostPosted: Fri Apr 30, 2010 9:58 am    Post subject: Reply with quote
fender sells replacement synthetic nuts but they are calibrated to a 9.5 inch neck radius, can these be used on 7.25 tokai? if not what is a good replacement?
