Author |
Message |
Ozeshin Guitar God
Posted: Thu Jan 21, 2010 2:22 am Post subject: Stereo cabinets |
Got a stoopid question...
How does a stereo cabinet work...I have a stereo Quad box and I'm about to add a second amp to my rig.
Is it possible to run both amps into the one cab....or do I need to A/B and only run one at a time? |
Back to top |
JohnA Guitar God
Joined: 02 Mar 2007 Posts: 4176 Location: Leicester UK
Posted: Thu Jan 21, 2010 2:49 am Post subject: |
Yes you can run both amps in to one cab, if they are valve amps DON't try to use an AB box after the amps to run them seperately, a valve amp must be connected to a speaker if it's switched on otherwise you will damage the output tranformer.
There should be 2 inputs on the cab, probably 8 ohms each, but check, use the 8 ohm connection on your amp and connect one amp to each input. You can use an AB box in front of the amps to run one at a time, or an ABY box to run them seperately or both together. |
Back to top |
Ozeshin Guitar God
Posted: Thu Jan 21, 2010 3:40 am Post subject: |
Perfect...ty for that John  |
Back to top |
JohnA Guitar God
Posted: Thu Jan 21, 2010 3:53 am Post subject: |
So what you got? |
Back to top |
Ozeshin Guitar God
Posted: Thu Jan 21, 2010 8:56 am Post subject: |
Bugera 1990 and an Ashton Viper 100...both valve. |
Back to top |
