JohnA said:Not a kit, it's based on a ceriatone 18W TMB, but with a few tweaks to use 6V6 valves instead of EL84's, I sourced all the parts in the UK, a lot of them from www.valvepower.co.uk, his transformers are excellent and very cheap! I have also installed VVR (Variable Voltage Regulation) which is like powerscaling so you can run the amp at bedroom levels and still retain the tone. Without the VVR and 18W is much too loud to use at home
Great Lucky of you that you know how to build a low wattage amp. Did you record anything?
