Greco no serials
japanstrat
PostPosted: Fri May 16, 2008 2:23 am    Post subject: Reply with quote
The headstocks vary. At http://www.cosmikdebris.co.uk/grecopics.htm#logo the guitar on the right is not a FujiGen or a Tokai and it has different features to all the Japanese guitars so I would say it's a Cort Greco even if the headstocks don't exactly match some other Cort Grecos. Depends on where Cort were getting the logos from and Corts cnc machines and how the cnc machines were programmed.
guitar.sib
PostPosted: Fri May 16, 2008 3:28 am    Post subject: no serial Reply with quote
At http://www.cosmikdebris.co.uk/grecopics.htm#logo the guitar on the right has exactly the same script as any other Cort Greco that i has met personally or on the net, but that third guitar on my photos has totally different script
that's confusing, and what confusing more, that i personally see couple FujiGen Grecos(not Tokai, and not Cort) with no serial(for the truth they were with chambered body, but still)
you see, whole picture for me looks like this: there is a bunch of a Cort Grecos, they all the same(head, neck, script, cavities, neck tennon, wiring), and this the only one(that i saw) that differs in all this specs, and in some(for example neck, logo, script) similar to japanise, but still has plastic wires and no serial. so it's totaly unclear, what the hell is that
guitar.sib
PostPosted: Fri May 16, 2008 3:54 am    Post subject: no serial Reply with quote
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290203616377&indexURL=8#ebayphotohosting
this guitar is similar in some ways (but has a serial)
guitar.sib
PostPosted: Fri May 16, 2008 3:57 am    Post subject: no serial Reply with quote
look closely in control cavity
japanstrat
PostPosted: Fri May 16, 2008 5:25 am    Post subject: Reply with quote
The differences I see between the 1988 Fujigen Greco above and the no serial Greco your talking about are, the Fujigen pickup routing has curves and your Greco is straight-ish, the Fujigen Greco has a rounded tenon end and your Greco has a squarish end, the Fujigen Greco has a sloped nut and your Greco has a brick nut, the Fujigen Greco has large pots and your Greco has small pots, the headstock shape is similar but doesn't match, the Greco Mint Collection logos match, the Fujigen control cavity wiring hole is in a different position to your Greco.
guitar.sib
PostPosted: Fri May 16, 2008 7:16 am    Post subject: no serial Reply with quote
this is just an example, i didn't said that they match exactly, but also have some common features
PostPosted: Fri May 16, 2008 1:36 pm    Post subject: Reply with quote
Thanks again for your tuition japstrat,it?s a joy reading your posts.
cosmikdebriis
PostPosted: Fri Jan 16, 2009 5:06 am    Post subject: Tokai made Greco Reply with quote
Hi... To be honest it is news to me that Tokai made guitars for Greco. Though I'm not surprised. The whole Greco history thing is VERY confusing to say the least.
Anyway, my query is... Do ALL/ANY Tokai manufactured Greco guitars have full sized 24mm pots? Also what sort of shielded cable do they use?
I've always assumed Korean Greco had "skinny" plastic coated wiring and 16mm pots.
As an aside.... The Greco on my web site... (Yes that's me)... that I've listed as Korean is made (probably) of Basswood ( I stripped the finish). It's certainly not mahogany and neither does it have a maple cap, or any kind of cap for that matter.
japanstrat
PostPosted: Sat Jan 17, 2009 1:23 am    Post subject: Reply with quote
From the Tokai made Grecos I've seen, they have large 24mm pots.
From the Cor-Tek Cort Korean made Grecos I've seen, they have both large 24mm and small 16mm pots and some pots are stamped "COR-TEK".
There are other things that can be used for a Tokai made Greco ID. The Tokais have 2 square shaped holes at the bottom of the pickup cavity and most/all other factories have 2 rectangular shaped holes at the bottom of the pickup cavity. So if it's a no serial Greco and it doesn't have the 2 square shaped holes at the bottom of the pickup cavity then it's a Cor-Tek Cort made no serial Greco. If it's a no serial Greco and it does have the 2 square shaped holes at the bottom of the pickup cavity then it's a Tokai made no serial Greco.
And there are still more things that can be used to ID the no serial Tokai made Grecos from the no serial Cor-Tek Cort made Grecos.
Basically, Kanda Shokai hired other guitar factories to produce Grecos in the late 80s because Fujigen was too busy with Fender Japan and Ibanez etc to make all of the Grecos in the late 80s.
20 century boy
PostPosted: Wed Jul 22, 2009 12:51 am    Post subject: Reply with quote
One of the most acurate way to tell if a Greco is Korean or Japanese is the finish: urethane= japanese, polyester= Korean. Unfortunately I don't know any accurate test to make the difference. Except the feeling of it.
After 93, most Les Paul models seems Korean, Only some SG, flying V and Firebird are japanese. Rick copies are still japanese.
nankurunai sa!
Freebird
PostPosted: Sat Aug 08, 2009 3:19 pm    Post subject: Reply with quote
I think many Greco Clear Sound Project semi-hollowbodies from the early 1990s are probably Tokai manufactured. My 1991 ES-335 copy seem to fit the descriptions mentioned. It has GOTOH pickups (HB-GBT) in both neck and bridge positions that I think Tokai used, but I can find absolutely ZERO manufacturer information on. Neck pcikup cavity routing looks Tokai.
FB
jujucaster
PostPosted: Tue Oct 27, 2009 1:51 am    Post subject: Reply with quote
Hi guys, I read the whole topic and am impressed with your knowledge.
Can you guys tell me anything about that guitar:
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=350249184795&_trksid=p2759.l1259
I haven't seen a lot of goldtops before and I find this one gorgeous.
(I just bought it)
PostPosted: Tue Oct 27, 2009 2:20 am    Post subject: Reply with quote
That ones is Tokai made,you can tell by the pickup routing the shape of the neck tenon and the offset to the left position of the neck joint.
Looks very nice, i just love Gold Tops....
jujucaster
PostPosted: Wed Oct 28, 2009 11:11 am    Post subject: Reply with quote
Thanks a lot Mick for your expertise!
I should receive that guitar tomorrow.
Should be a fine guitar yes?
jujucaster
PostPosted: Fri Oct 30, 2009 10:53 am    Post subject: Reply with quote
I received it and wow!!!
It's my first greco LP and I can't believe how well built it is.
I bought a Gibson Lp standard once and brought it back to the shop after 4 months. It was gorgeous but rubbish.
I didn't try this one on an amp yet but acoustically it rings.
Well that's it...I'm very very happy.
Page 3 of 4
