Momose MC-2 Strat
Australia
I couldn't wait any longer to post some pics of this beauty! I'm waiting on a pickguard and still have to put the original bridge back in.
Also waiting to find out if the slab board is Jacaranda, it's supposed to be.
Has some fret edge binding similar to the Seymour Duncans:
Here's the bit that will upset MIJ and other purists! (and maybe the 22 fret neck)
I don't know a great deal about what makes a top Strat, but this one sounds great and is very easy to play, so I reckon it's good enough for me. Remains to be seen whether I can be a Strat player or not...
Dude that is quite simply stunning! Personally I think (just going by internet info) that momose are pretty much a cut above nearly everything. That looks like an entire strip of rose wood binding the fret ends! Crazy.
The ash looks amazing and the finish is sooo classy.
As for the headstock I really don't care anymore. (even though my Seymour Duncans have them) In my opinion these japanese guitars out do nearly everything fender has to offer. I like the fact that the headstocks are different because I DON'T WANT a fender. And the momose headstock is totally classy.
Seriously I don't think you'll find a strat any better than that anywhere.
That's exactly what it looks like - strips of rosewood used for neck binding. Could be a problem for re-fretting in the future, maybe have to send it back to Japan for the job because nobody's up to it outside Japan (Lol)?
I agree about the headstock shapes; I'm just happy now that I've found some quality Japanese guitars with their own unique differences. I would buy a Fender Custom Shop, no probs, but I can't afford it. Besides I don't have to afford it with other options available like this Momose.
Thanks for the kind words, and I suspect this one is pretty good - plays really well. I'm looking to customise it with a black pickguard, but I may have to get it custom made if Deviser don't answer my emails.
You'll remember we were discussing the mystery DS-200/250 with changed pickguard, and while I was messing around with questions on that, this came up so I threw on a bid and ended up winning it. From that you will know what I paid for it (I got very lucky). If I had missed out on this MC-2 I would have bought the DS.
Cheers
Raph
Awesome! I love those Momose strats, even with the wacky headstock.
Glad to see you finally got your strat, even if it isn't a Duncan.
I'd suggest tortoishell for the pickguard, that would look cool. But yeah, you'll probably need a custom made guard as it's slightly different in shape to a Fender.
Lovely guitar. As you say the fingerboard should be jacaranda on an MC2-STD/NJ. Is there some reason you think it isn't?
Dave
Dave
I did find the following info about the 2007 model:
http://www.japanvintageguitars.com/Momose 2007 MC1-STD.html
My MC could be from 2007/06 I don't know yet. Also, I'm can't recognise jacaranda just from looking at it, what's it supposed to look like?
MIJvintage said:
here's a link to my 2000 Tokai LS-320
http://tokaiforum.com/viewtopic.php?t=10573&sid=db412f08ca1af658b8f085ccbdc29b7a
There are a couple of pics of the Jac' fingerboard; that may help .................
The jac board on yours has nicer figuring than mine (if it is jac), I'll withhold judgement until I've oiled and polished it because it seems a bit dusty and dry at the moment. Is it ok to use normal fret board oil on it?
MIJvintage said:
nice Momose there; the ash with rosewood should be a great sounding lumber combination.
It's sounding good so far, but I've got to use it in a few other situations to get a proper handle on how it sounds.
MIJvintage said:
I have a light weight ash body Strat with a slab board neck; one of my best sounding lumber wise :)
I will weigh it at some point - seems pretty light, maybe in the low 3 kg range, or about 7 lbs.
Yeah, as I said, I would have bought that Duncan, but I got no answers at all about anything from the guy, and just when I was about to gamble on it, the Momose popped up.
I'll definitely look at the tortoise guard, good suggestion! Hopefully my local guy has a couple of Fender guards in stock and I can just sort of lay them on top to have a look.
Here's a link to a nice pic of an MC-1 Std NJ (alder body) and an MC-2 STD DX NJ with a jacaranda fingerboard.
http://toguitars.com/gallery-japan/MOMOSE/momose-003.html
http://toguitars.com/gallery-japan/MOMOSE/momose-006.html
edit: And also here same as yours:
http://www.tcgakki.com/thumbnails/?p=016948
I'm sure you know, but just in case, the NJ stands for New Jacaranda. So unless that's a clever description of something else it's jacaranda.
Dave
DaveWW said:
Dave
Nice one Dave, thanks! :)
The seller advertised mine as MC-2 STD/NJ (Nat), so it should be jacaranda, but it wouldn't be the first time someone has looked up the current specs and used them to describe a guitar that's a few years old which may have had different specs.
On the plus side, your last link that shows a guitar identical to my one, reveals that my serial is only 12 numbers earlier than the one in the link. If that one is jacaranda then mine probably is too. I'm not really going to mind which wood is used, as it's still a really nice Strat either way!
Raph
I think the answer about what is New Jacaranda, which they've been referring to since about 2004, is here -
http://plaza.rakuten.co.jp/kootheguitarist/6010
..................but I'm not 100% sure what is says - perhaps Joe can confirm?
Dave
Dave
Here is a translation NOT the translation:
"NEW JACARANDA< [niyuhakaranda] >
are high-class in just [hakaranda] and the [yu] !! As for
the laughing place of origin the South America/Africa
mainly feature of the ☆★ wood which is used as the side material
back material: Weight a little more heavily is the [me].But, it is superior in durability and also sound is good.
Feature of sound: The sound to which attack is strong, dries sounds.
As for this, the one which you think that [hakaranda] it is cheap comparatively? It is not [bu] [tsu] [chi] [ya] [ke] [hakaranda]!!
Natural shape is the rose wood!!
The first class mahogany (the Honduras rose wood) is called NEW JACARANDA*"
It appears to be in reference to acoustic guitars. Some say that Jacaranda = Brazilian Rosewood when referring to fret boards, but I haven't found much on the web to back that up. So what is New Jacaranda? The translation above seems to say it is first class Honduras Mahogany or "Honduras Rosewood" which seems a little strange? The Jacaranda tree is definitely in the rosewood family, so using the name rosewood to mean mahogany doesn't seem right. It could be like a slang term or urban myth or something.
Dave
8) no problemos babe!
@ jacaranda..........brazillian rosewood........
@ new jacaranda........honduran rosewood.........
@ ozemic............. ozeshin&mick ..................
:wink:
http://www.northridgehardwoods.com/
8) email this company your questions about the woods.......j
Dave
After a while you get used to Jinglish, that one says the the "new jacaranda" is Honduras rosewood.......not the mahogany.. :wink:
