Hi Ian,
I've done several complete re-finishes on Strats using nitrocellulose, & by far the very best results I've got were by finishing off using Stewart MacDonald's polishing compounds - indistinguishable from a very good factory-finish. The white ( & earlier pics blue) Stratocaster in the pictures on my homepage (link below) is a good example.
For your purpose, "glossing"-up a matte finish, I'd recommend you just use the "fine" and the "swirl remover" - you may get away with just the swirl remover by itself, but it will be a much longer job!
This is a rather long URL, you may need to copy & paste it in your browser if you can't get it all on one line...
http://www.stewmac.com/shop/Finishing_supplies/Abrasives,_polishes/Stewart-MacDonald_Polishing_Compounds.html
In order to cut down on the "elbow-grease" (though a hell of a lot needed anyway!), I got a couple of polishing wheels too, to use with an electric drill - very nice pro results in a lot less time! - much more even than doing it by hand and far less chance of "polishing through' the finish too! 8)
http://www.stewmac.com/shop/Finishing_supplies/Abrasives,_polishes/Finesse_Polishing_Pad.html
You'll need one for each compound - label them so you don't mix 'em up! Luckily none of this stuff is very expensive.
StewMac stuff seems to arrive here (Hong Kong ) about 3 days after I order it,
very fast service!
Be
very careful to just polish enough with the fine compound to remove the matte finish, the swirl remover will then give the gloss finish without applying a lot of pressure - you
really don't want to go through the clear coat into the colour coats beneath.
- If you DO accidentally polish through the clear-coat finish, it's actually fairly easy to add another clear coat using nitrocellulose spray cans - if you're careful - but
completely clean the surface with naptha (lighter-fluid, usually sold as 'Zippo' or 'Ronson' in tobacconist's) first, and make sure the room is warm & well ventilated. Wear a face mask. Several very light coats is better than one thick one, which may 'sag' and even 'craze' later. (Don't spray nitrocellulose onto polyester or vice-versa, there wil be a chemical reaction & you'll prolly have to strip the guitar & start over from scratch!) 1500 wet-n-dry paper after each couple of light coats and finally 2000 grade. Use plenty of water on the paper (even a little dish-detergent on the final polish before using the StewMac compound). This easy on a Strat or Tele becasue of the flat surfaces (wrap the wet-n-dry paper round a flat block of wood, or a couple of empty cassette boxes stuck together, to keep it even on flat surfaces, find a curved or rounded object to wrqp the paper around for sanding non-flat surface)) - but on a carved top like a Love Rock your elbow 's are gonna hurt! In the next step, the fine compound gets rid of small unevenness from sanding, and the swirl remover gives the glossy finish.
I should add that I also used the compound & swirl remover to "clean-up" a friend's old & well-gigged 80's Strat (he wanted to give it as a present to his son) and the polyester finish was VERY different - it took a LOT more work (maybe 30 to 40 tims as much!) over several days (...and ruined the polishing pads by the time I was finished - almost killed the electric drill too!). :-?
Got the job done in the end, but I won't be messing around with a poly finish
ever again. :roll:
For your sake, I hope your finish is nitro!
Good Luck!
