Tokai Talbo II Super Brilliant
ricardormz
Hello. New to this forum. Got this Tokai Talbo II Super Brilliant guitar. I can´t seem to find any information for this specific model. Different headstock, different logo and different model "Tokai Super Brilliant".
Any info is appreciated. Thank you!
An odd one indeed. Any serial number to be found on it?
No Talbo 2 in any of the catalogues nor that headstock profile. 4 bolt neck is the normal too.
Could be an early type for evaluation. Hopefully someone will come along with getter experience of this range.
Might help but I'm not sure where the numbers usually are. Yours looks old enough to be around early 80's and why it may be an alternative design consideration.
Send pictures to Tokai Gakki and see if they can help.
Early '80's Talbo had two bolt neck. Two on ebay in the UK recently. Never seen this headstock though. As far as I know the serial was just a decal at the neck just above the neck/body joint on the back
