Source of brass M4 posts and steel bushings for Tokai LS
StugIII
Active member
Spain
Hi.
My Tokai LS-Custom came with brass busings and brass M8 studs for the lightweight stopbar.
And the bridge posts are steel M4 screws.
I seems that original LP'59 had steel bushings and studs for the lightweight stopbar and brass posts at the bridge. Just the opposite.
I would like to replace bridge posts and tailpiece bushings with the correct material. Do you know any source for these parts:
- M4 brass screws, nickel plated for the bridge
- Steel bushings for the tailpiece, which fits the diameter of Tokai holes.
Do you know any source for them?
Regards
Stug, just try http://www.montreuxguitars.com/products/import/pu_parts_us.html
Give me a call and let?s see how can make it.
Philadelphia Supply had them in stock too, I have a pair left if you need them fast Emiel.
It's worth bearing in mind that those old brass bridge posts are much softer than steel and over time had a tendency to bend under string tension.
IMO for technical and practical reasons stainless steel is a much better choice.
